    Results 1 to 9 of 9
    Thread: power steering
      power steering
      hello everybody ,,,
      i just wanna ask about the best deal on a Rack and pinion(power) kit for my 1969 firebird ,,,and how sells them ,,,
      thanks and regards
      mohannad
      and will a unisteer rack kit fit my DSE control arms with no problems ? ?
      regards
      Apr 2010
      Rumson, NJ
      I have a Steeroids rack on my '67 'bird. Tightened everything up and really changed the car, but steering feel is lighter than I would like. Only other gripe is that the rack and bracket hang very low - I need to really drive carefully everywhere not to scrape. This summer I am going to try and fix this issue.
      '67 Firebird convertible
      excellent ,,, r u using stock control arms ? am using DSE arms a coilover's ,,, will a rack setup fit ?
      thanks and regards ,,,
      Winter Park, FL
      I didn't think you could use a rack & pinion on the firebird without modifying the subframe. The problem has been the pontiac motor mounts are right where the steering shaft needs to go. Is the steeroids a rear steer mount? Do you have a pontiac or ls motor?
      69 Firebird Convertible.
      www.stevegarrison.com click Firebird link at bottom of page
      i will be using an ls engine ,,, does that change anything ?
      regards
      up up up
      guys need help plz
      Chicago suburbs
      Can't say for sure about a pontiac, but I'm pretty happy with my Unisteer rack in my 69 Camaro, it all tucks in very close. My only complaint is the outer tie rods are not greasable, and you really need to use 3 u joints. I don't see how DSE control arms would be a problem, I'll be buying some soon.
