Results 1 to 11 of 11
Thread: what FI for my engine?
04-05-2010 #1
Starting The Transformation
- Aug 2009
- Langley BC, Canada
- 264
I was wondering what is a good efi system to use? I am thinking of switching to help emissions and MPG on m motor.
I am not familiar with it at all but was thinking a system with fuel rails and individual injectors for each cylinder would be more efficient than a throttle body injection?
I would also in the future like to possibly step up to a super charger if $$$$ ever allows it too, if that changes any choices.
Here is what I am working with currently.......
ENGINE
-383 stroker 442hp/470ft lbs of torque )
-Chevy 350 bored 30 over and stroked to 383ci
-Scat crank 3.75 Stroke Cast 9000 series
-Scat 5.7 forged I beam rods with 7/16 arp cap screws
-Forged Flat top Probe Sportsman Race Series Pistons
-Comp Cams Roller Cam Duration-Intake 230deg Exhaust 236deg @ .050 / Lift Int .510 Exh .520 and 110 lobe separation
-Air Flow Research 195cc Heads 74cc chambers
-9.7:1 compression
-Headman Block Hugger Headers
-Holley fuel pump
-Speed Demon 750cfm Carb Vacuum secondaries
-Polished Air gap Intake
-Edelbrock aluminum water pump
-MSD Plug Wires
-All Bolts Are ARP
-Mini Starter
-Edelbrock double roller timing set
-Comp cams roller lifters
-Crane cams roller rockers
-Full Mandrel bent Flowmaster American Thunder exhaust With 50 series deltaflow mufflers
CHASSIS
-700r4 tranny
-B+M super cooler tranny cooler
-9 inch ford rear end
-Center Section With Motive 3.89 Gears And Auburn Pro series limited slip
-Air lift easy street air ride kit
-4 wheel disc brakes
-18x7 in front and 20x8.5 rear Intro Twisted Vista Wheels -Boxed trailing arms in rear by spirit engineering
And the dyno specs....
Intake center line 105 1/2
jets 76 front 85 rear
vac sec spring short yellow
timing 35 deg
RPM----HP----TQ----A/F--- Vol Eff%
3900 - 328 - 442 - 13.3 - 97
4000 - 340 - 447 - 14.0 - 97
4100 - 356 - 456 - 14.2 - 97.3
4200 - 370 - 462 - 14.0 - 97.5
4300 - 381 - 465 - 13.9 - 97.5
4400 - 390 - 465 - 13.9 - 97.4
4500 - 397 - 463 - 13.8 - 97.4
4600 - 404 - 461 - 13.7 - 97.2
4700 - 410 - 458 - 13.8 - 97.1
4800 - 416 - 465 - 13.8 - 96.9
4900 - 422 - 452 - 13.8 - 96.7
5000 - 427 - 448 - 13.8 - 96.3
5100 - 430 - 443 - 13.8 - 95.8
5200 - 433 - 437 - 13.9 - 95.2
5300 - 435 - 431 - 13.9 - 94.9
5400 - 436 - 424 - 13.8 - 94.6
5500 - 437 - 418 - 13.9 - 94.3
5600 - 439 - 411 - 14.0 - 94.0
5700 - 440 - 406 - 13.9 - 93.5
5800 - 442 - 400 - 13.9 - 92.8
5900 - 442 - 393 - 14.0 - 92.1
Thanks.......
6000 - 440 - 385 - 14.0 - 91.5
Kevin Freund
1961 Impala Drop Top
04-06-2010 #2
You have many options to fuel inject your Impala. I'll give an overview of some of the systems. Others more knowlegible can fill in the gaps.
OEM injection:
You can convert to factory injection using either a factory harness or an aftermarket harness.
TPI injection was offered from 1985 - 1992 on Camaro's, Firebird's, and Corvettes. From 85 - 89 was Mass Air Flow Systems. 90 - 92 was Speed Density. Both have their pros/cons.
You can also buy aftermarket parts to compliment and/or completely replace the factory parts. The factory TPI consists of a base manifold, a pair of runners, and a plenum. A throttle body bolts to the front of the plenum. A factory style system only flows well to 4500 - 5000 prm due to the long runners. Porting the plenum and buying larger diameter runner tubes will help but they have their limits. Supercharging can overcome this as it forces the airflow thru. Larger injectors and throttle bodies can also be bought for more fuel flow and airflow.
The TPIS MiniRam is simular to the Chevy LT1 intake. The Holley StealthRam is simular to a Tunnel Ram intake. Both are complete in the fact they replace the intake, runners, and plenum all in one peice. They still use the Chevy wiring and sensors. The throttle body still bolts to the front. Both are good systems and can be bought with just the manifold or a complete EFI swap kit with all sensors and wiring. Both these systems have shorter runner built into the intake and can result in higher rpm capability.
All of these are the Multi-Port type with an injector for each cylinder. These Chevy injections use a chip contained in the ECM (Electronic Control Module). You can have aftermarket companies tune these by mail order or you can buy the equipment to tune these yourself cheaper than 1 aftermarket chip. If you are good at tuning or catch on to tuning basics easily, this is the best option.
Aftermarket Injection:
Many companies markets fuel injection that can be either adapted to a stock style single plane intake or bought with one already converted. They too, have an injector for each cylinder. They come with the harness needed to run the system and contain an aftermarket ECM that can be tuned with a laptop. The throttle body on these sit on top and resemble a carb but only flow and meter in air. All injection systems that have the injectors near the head flow air only thru the intake and are called *dry flow* as the intake only flows air. The fuel is added near the head.
There is also the injection system that have the injectors near where the carb would sit. This is the throttle body injection you said you wanted to avoid, and for good reason. They are just basically an intelligent carb. But still just basically a carb. They have the same airflow problems a carb has such as flow and fuel dropout with low velocity. They typically have either 2 or 4 injectors located where the carb sits. Good for a stock replacement but for performance, steer away from these. Not to be confused with the throttle body used on a multi-port system.
I hope all this ins't too overwhelming. It is just a small overview on EFI. A good injection system will make you forget all about carbs. When I swapped a TPI into my car (also AFR 383 powered BTW) it wasn't even tuned correctly but it was still better than any new carb I ever had. I can only imagine how good it would have been if it was. I'm getting ready to drop my rebuilt 383 back in my car with a few additions added so my tuning will start all over again. I plan on getting PCMforless.com to burn me an initial tune for a safe startup.Doug Gulley
66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
04-07-2010 #3
- Aug 2009
- 264
Thanks for the info Doug, it was a good read. I am glad my common sense was right about the throttle body injection.
Kevin Freund
04-07-2010 #4
Not a problem Kevin. If you already have a throttle body setup from a donor car then it may be worth considering. If you have to buy everything for the swap, myself, I'd just stay carbed. The multi-port is DEFINATELY worth swapping to!
Doug Gulley
04-07-2010 #5
