    Results 1 to 9 of 9
      Eastern Virginia
      ? mounting Autometer gauges.
      I am trying to figure out how to mount a full set of Autometer gauges in an 80s G body. The problem is they are small & I want mount them in the stock location. I want to go with Autometer, but in the models I like the smallest they make is 2-1/16" to fit in the center 4 spots:
      So for those of you that have mounted these gauges, is the area that is represented by dimension "A" in the below image able to be trimmed so they can be mounted closer together?
      So I can do something like this:
      Doesn't gain alot, but any bit helps.
      Scot
      86 Monte SS
      St.Anne Il
      the trim ring is aluminum so could possibly trim them down...like you have pic of
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Mar 2002
      North California
      Eastern Virginia
      Quote Originally Posted by dropit69 View Post
      So is this trim ring what holds it onto the panel, or is there a lip on the can that holds it?
      Scot
      86 Monte SS
      Apr 2002
      North Central Texas
      Quote Originally Posted by Samckitt View Post
      There is a lip on the can that sets on the panel and the trim ring is crimped onto the lip. Then on the backside of the Autometer gauge there are 2 threaded posts and a mounting ring that goes over the threaded posts and presses against the panel securing it. I hope that makes since.
      Shannon
      Modo Innovations
      940-391-9002
      Eastern Virginia
      Quote Originally Posted by Modo Innovations View Post
      Yep it makes sence. So I take it Dim A that is on the Autometer image above is a bezel that doesn't even have to be used.
      Scot
      86 Monte SS
      Apr 2002
      North Central Texas
      I think the bezel holds the glass in/on the gauge and is also used as trim. I know that on a Stewart Warner gauge ("5) the glass is held in by glue and the bezel covers the glue line and is also used as trim.
      Shannon
      Modo Innovations
      940-391-9002
      Jul 2009
      Abbotsford,B.C.
      My buddy makes a panel for malibu/monte that replacec the whole facia & you cut out your own holes where you need them PM me for his email address .
      Just trying to do things my way , like it or not !
      Eastern Virginia
      I have seen some of the aftermarket ones & to me they don't look quite right, or out of balance.
      Example:
      Scot
      86 Monte SS
