Results 1 to 12 of 12
New to Pro-Touring
- Dec 2009
- 10
68 GTO...BACKHALF OR NOT? dilemma
Hey all, well yesterday i brought in my bare chassis to have boxed and cross-braced. After telling the fabricator what i was looking for(strength in the chassis for handling the motor, handling). I plan on running the Moser 12bolt, because ive heard the 10 bolt just wont hang. He called me a few hours later and said two options, The first being exactly what we talked about-cross-bracing, custom cross member, boxed frame, and running that 12 bolt with some hefty aftermarket uppers and lowers with coilovers. For that $2900 for just the metal work on the chassis (not including 12 bolt, arms or springs) or Completely Back Half the frame, mini tub it so i can run 315's or 335's, box and crossbrace like before, and fab up and 1 off 4 link system. Without the rearend, the price is $4900. Im not really sure where to go guys. I would love to fit some wider tires and have the rear suspension bullet proof, but at the same time its a lot to bite off. If you understand what i mean. The cars intention is to be a no BS street brawller, and will probably see the track here and there. Im just looking for your guys experience and knowledge. I realize im probably leaving a lot out, but im really kinda stuck here. Thanks for the help-Daniel
03-25-2010 #2
Banned
- Aug 2003
- Orlando, FL
- 8,745
We have done a couple of these. Those frames narrow up real easy. You will need a $500 coil over conversion, We can order a Moser rear with the upper arm bosses attached and lower arm perches loose, about $2500. The $4700 if that is just labor and the frame is already on the floor is strong. I sent my brother to North Carolina to do one for another shop and he did it in 3 days start to finish, 24 hours, X $60, $1500 labor.
03-27-2010 #3
- Jan 2005
- Netherlands
- 1,012
[QUOTE=ProdigyCustoms;651014]We have done a couple of these. Those frames narrow up real easy. QUOTE]
Any pictures of that???
03-29-2010 #4
Banned
- Aug 2003
- Orlando, FL
- 8,745
[QUOTE=Roadrage David;651805] Here is a 65, same deal
http://www.prodigycustoms.com/projec...s.php?album=15
03-30-2010 #5
New to Pro-Touring
- Dec 2009
- 10
hey guys, thanks for the feedback. As it turns out after i talked to Marcus at SC and C, and re-thinking where i am going with this car, im not going to back half it. I got wrapped up in the snowball effect and at the rate i was going this thing was going to turn out a full on race car.haha. So we did some engineering, and the frame is going to be boxed, new crossmembers, and some crossbrace work, We are also going to notch the rear about an inch to make a little room just as you guys said. Then off to be powdercoated gunmetal. Im trying to load pics but Im not allowed to for some reason. I will keep you updated, should be a really fun car.
04-01-2010 #6
New to Pro-Touring
- Dec 2009
- 10
Still cant seem to load pics! Help?
03-26-2010 #7
