      Aug 2009
      Crossmember Fabrication
      My New headers on my GTO may hit the factory crossmember and I am looking for options. I was going to make a new crossmember out of 1" square tubing, but I am not sure if that will be strong enough. Thoughts?
      Feb 2010
      BFE
      1 in is kinda small
      you would need to gussett any stressed areas,
      minumum .125 wall, think of the stess this handles.
      Dec 2007
      Carlsbad, Ca
      could you just cut some out of the factory piece to make it work, or is it going to remove too much?
      Tim
      Build Thread Link
      Mar 2010
      Central IL
      Vintage GTO or Monaro?
      Sean
      The difference between stupidity and genius.... genius has limits
      Oct 2009
      Ever think about getting some chromoly tubing and bending one to fit your needs? Popular Hot Rodding did one on their project Laguna in an article awhile ago, very simple and came out very nice. As soon as I get the engine and trans mocked up in my car i'll be doing the same thing.
      Many options depending on your skill set and/or tools...or just how big your pocket book is. Send some pictures. If you need just a small amout of room then scalloping a small curve out will do. Then welding a shaped patch back in with similar wall thinckness is typically how it is done. If your looking for something more ellaborate let me know and I can get you directed in the correct direction.
      Brett,,,Campbell Customs metal fabrication.
      May 2001
      Mesa, Az.
      Quote Originally Posted by Dstoltenberg View Post
      While Chromoly is definitely overkill for this part on most vehicles, standard 1.75" .120 wall DOM would be plenty strong and easy to work with if you have the right tools. Many times I just cut the factory one apart and make it fit. Then weld it all up and paint.
      Phillip
      May 2002
      Northern California
      good points Phillip
      anyone make an aluminum one?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
