      SPEEDO Sending unit! Please help..
      OK heres the deal... I have a dakota digital dash setup in my 65 fastback. I have a 4 speed toploader in the car. Everything works great except the speedo wont calibrate. It only reads zero.. so I pull the speedo sender wires and check them with the speedo sender in place and attached to AC voltage meter, start the car and nothing reads.. BUT when I pull the sender out of the tranny and spin the gear with a drill then I get a voltage reading... I did this according to the tech at dakota digital then it was the end of the day for them and they closed.. So I know the sender is good but it must not be spinning when it is in the tranny and the car is in gear(on jackstands).. so what could it be? Has anyone else had this problem? I used the gear off of the old speedo cable that I replaced but come to think of it I am not sure if that was working either(been a while) so what else could it be. I can see the speedo gear IN the transmission tailhousing but it seems to be bigger on one side than the other. Could that gear INSIDE the tranny be worn and if so HOW HARD IS IT TO REPLACE IT? How do you replace it?? Thanks In advance.
      Mark
      TOOFUN
      Mar 2010
      Central IL
      Leave the cable unhooked and visually verify that the driven gear is moving. I went through the same thing on my formula turned out to be a bad gear. The keyway/slot for the cable was stripped. If the driven gear is moving check for good fit at the cable if isn't replace the gears. Never had a top loader so I can only speculate on difficulty but it can't be too hard.
      Sean
      The difference between stupidity and genius.... genius has limits
      Speedo DRIVE gear is worn out...
      Well I figured it out... The gear inside the tranny is moving when the driveshaft is moving BUT it is all worn down (its a plastic piece on the Ford Toploader)... So it looks like I am going to have to replace the speedo drive gear on the tail end of the tranny.. So has anyone done this before? How hard is it with the tranny still in the car? Do I need any special tools? If I have a transmission shop do it what would it cost? Just sold the car and want to make sure it is done right but quickly for the guy who bought it from me..
      Mark
      TOOFUN
      Mar 2010
      Central IL
      It is a pretty straight forward operation.
      1. Drain fluid
      2. remove drive shaft
      3. Unbolt trans mount from trans or crossmember (whichever is easier)
      4. support trans under main case
      5. unbolt remaining crossmember bolts and remove (may have to jack trans up a bit depending on configuration)
      6. unbolt and remove trailshaft housing
      7. remove snap ring from tailshaft and slide gear off
      No special tools needed.
      I recommend changing the rear seal while you have it apart.
      Here is a pic disregard the shaft he is pulling as it is not relevant to you.
      Sean
      Hey Sean,
      Thanks for the info! That is funny I actually was just looking at that EXACT picture from mustangs monthly about 5 min ago! It really shows the Speedo Drive gear perfectly! Also, a local tranny shop said to use anaerobic sealer instead of a tailshaft gasket when putting the tail shaft back on.. What do you think of that??
      Mark
      TOOFUN
      Mar 2010
      Central IL
      Agreed as it is used for rigid machined surfaces and cures even if air is not present.
      Sean
      Wrong parts or right ones??
      OK,
      Probably a bit dramatic but I am so sick of misinformation from sites and tech people that think they know what they are talking about judged on books and not hands on knowledge so here it goes...
      I need a new Speedo Drive Gear since mine is apple cored out... So I called Mustangs Unlimited and they sent me two gears.. One for the tail shaft for the tranny (4 speed toploader) and one for the speedo cable.. Problem is the teeth run bottom left to upperright on the speedo drive gear and they run bottom right to upper left on the cable gear! IS THIS RIGHT? The tech at Mustang Unlimited say it absolutely is correct according to his book but I cant see how mechanically it would work? I have included a picture for a reference PLEASE CAN SOMEONE WHO HAS HANDS ON EXPERIENCE WITH THIS ANSWER ME AND LET ME KNOW IF THIS IS RIGHT.. I dont want to rip the tranny tailhousing off and put it all back together again only to find out that this "tech" is WRONG.. Thanks In advance!!
      Mark
      TOOFUN
