    Results 1 to 3 of 3
      Spectra Fuel pump
      Does anybody know how much horsepower the stock pump that comes in a spectra EFI tank GM 32AFI (67 - 68 Camaro) support? I will be putting using it with an LS 2 around 400 RWHP
      The specs they give are
      " STOCK-CAPACITY fuel pump 85-115 PSI / 50-60 GPH"
      Sep 2008
      Kathleen, GA
      about 550 flywheel hp, based on output specs (+ safety margin)
      Newbury Park, CA
      50-60 GPH at what specific pressure? It takes one heck of a pump to make those numbers at 85psi.
      A Walbro high-pressure 255LPH only makes 43GPH @ 90psi.
      The pump is likely similar to a 4th gen LS f-body.
