Results 1 to 17 of 17
Thread: lt1 alt/charging help!!
03-23-2010 #1
ok so some reason my batts not charging it could be the way i have it wired but im not sure, so if u guys could let me kno how u have your charging system wired that would help a lot im tired of going out tp start the car and it being dead all the time!!!!(there is a draw in the system to but ill look for that after i fix my charging prob)
https://www.pro-touring.com/forum/sh...ad.php?t=22724
65ss chevelle
95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
63ss nova
350:cam headers,roller rockers.pete jackson gear drive,
th350 shift kit 3,500 stall
3:73
**Drive it like you stole it!!
03-24-2010 #2
- Feb 2007
- USA, TN
- 850
What is the voltage at the back of the altenator and battery with the engine running at about 2000 RPM? Need to check it with a light electrical load and a heavy electrical load. If the Altenator and battery maintain 14+ volts, the charging system is working.
03-24-2010 #3https://www.pro-touring.com/forum/sh...ad.php?t=22724
65ss chevelle
63ss nova
3:73
03-25-2010 #4
- Feb 2007
- USA, TN
- 850
You will not know until you measure voltage at the altenator. The voltmeter only tells you what voltage at the gauge is. There are lots of things that cause voltage drop. If you wired your sense wire to the back of the altenator, I would expect the voltmeter to read less than 13 volts. If your wiring is undersized for the length of the runs, then the gauge will only see 12 volts.
03-25-2010 #5
