Thread: HELP with cam installation
- Feb 2008
- 21
first of all I would like to say hello!!!!
well I removed my old cam the other day I brought up #1 cylinder to tdc my balancer was at 0 on the pointer my old timing marks were maybe one tooth off from lining up perfect I installed my new comp cams cam kit part # k11-250-3 it has a 574 -578 lift and 240-246 duration at .50 I put the timing chain and gears that cam in the kit in and in order to line up the dots on the gears I had to turn the crank which brought my #1 piston down and now my balancer is sitting at 40 degrees on the pointer you might ask how do I know that ? I put timing tape on my stock balancer starting at 0 from the line on the balancer and going up in #s can anyone tell me if I try to start the motor is it going to run or did I do something wrong ? I called comp cams today and explained this to them and they say it will be fine to just line up the dots on the timing gears just wanted to check with some experianced builders and see if anyone else has ran into this problem
thanks Les
