    Results 1 to 13 of 13
      FAST XFI help... stopped running.
      I figured I'd pose the question on here since I'm at my wits end searching for the problem. Here's the scenario.
      Car was running fine. (69 camaro, SBC, FAST XFI, close tune but not all the way finished). I took the car out on the weekend (2 weekends ago) and it ran fine. Changed the oil and washed the car, then drove it for a little while and parked it like normal. No spirited driving, didn't get in it once. Came back on monday and the car would turn over but wouldn't fire for some reason. I sprayed starting fluid in the throttle body and it would fire but die... something fuel. I unhooked the fuel line at the crossover and it came out like a fire hose... plenty of fuel, plus you can hear the pump running so it's not the pump. I figured it was the 30 amp relay that is on the wiring harness, or possibly the 30 amp fuse in the fuse holder, also on the wiring harness by the computer. Both are good to go, I double checked them with a test light. Checked all the grounds I could find and they were all good grounds, verified with a test light. The lights on the box all flash, though the injector ones look really dim when they are firing. Here's the kicker. With all 4 plugs that plug into the back of the FAST XFI computer plugged in, the car will turn over but not fire, even though all lights are flashing correctly (though the injector ones are dim, like previously stated). If I un-hook the blue plug from the back of the FAST XFI computer, the car will fire and run for a few seconds, then die. If I un-hook it and let the car fire off, then quickly plug it back in, the car will run for a little while, though if you touch the throttle, it instantly dies. I'm stumped here!!!!!!! Sorry for the long winded explanation, I've tried to explain everything as best I could. Any help would be awesome as this is killing me!!!!!!!!!!!
      00' WS6 Trans Am
      Incon TT.. now custom twin t-66's and A2W...
      http://media.putfile.com/twin-turbo-startup
      55' chevy Bel Air... 4 dr, but still a fun project!
      67' Camaro RS/SS clone... hers
      69' Camaro... another clone, FAST XFI, Procharger
      Mar 2010
      Central IL
      Have you hooked it up to your laptop to look for abnormal sensor readings? Such as TPS being over 80 which places the system in clear flood mode (spark but not injector pulse). Check for proper RPM during crank should be somewhere around 200. MAP should be around 100kPa with the key on engine off.
      Are you running it in bank or sequential mode?
      it is sequential, but when it is starting , the injectors look like they are firing in bank to bank. Once it is running, it looks like they are in sequential, again, just judging by looking at the lights on the computer. I tried hooking my computer up to check it, but it wouldn't connect for some reason. I need to re-check the settings on the com port I guess.
      I just checked online for guys having problems connecting to their usb com ports and it appears that it doesn't like windows 7. Their is a driver for it though, so I'll try that.
      00' WS6 Trans Am
      Mar 2010
      Central IL
      Based on what you are describing I am leaning towards a faulty cam sensor. One way to determine this is to configure for bank fire and see if it runs that way. Bank fire doesn't need a cam sensor input.
      What are you using for the cam sensor?
      Im using the dual sync distributor supplied with the FAST XFI setup for the cam sensor. I downloaded new drivers for the C-com software and I'm re-downloading the software to see if that helps out. Thanks again for the help. I won't get out of class tiull later tomorrow, but I'll definetly check to see If I can get my computer to link up.
      looking at the pinouts on the ECU, it looks like the big thing that the B harness on the ECU controls is the IAC stuff.
      00' WS6 Trans Am
      I agree with the advice above. You can look at the cam sig led while cranking and see if it blinks. You can pull the cap off and watch the led on the cam sensor and see if it comes on also. I would have to check but I thought the xfi started in bank to bank and then switched to seq when running. Dont quote me on this
      Tom
      I think your right about the bank to bank, then sequential. The cam light lights up on the ecu box. All lights do, but the injectors lights are real dim.
      00' WS6 Trans Am
      Any updates???
      Tom
      I haven't had a chance to touch the car due to getting out of class late every night this week. I will be putting in alot of time this weekend and calling up the FAST help line also. I'll keep you guys informed when I get back into her.
      00' WS6 Trans Am
      well, nobody was working at the fast tech line today apparently, since I kept getting a recording. The number listed on the website just kept ringing with no answer. I found the problem. It was the TPS sensor of all things. I finally got my computer to hook up to the ECU and noticed a TPS reading of 100% at idle and it was idling high. I unhooked the TPS sensor and it cranked right up and idled between 850 and 900 consistently. If the ECU sees a TPS reading of 80 or higher, it will fire the spark, but not fire the injectors, which is why my spark was good but my injectors wouldn't fire for some reason. I'll figure out the part number for the TPS sensor and go ahead and get another one installed. Other than that though, she is running good again, and I'm going to start logging and tuning. More to follow.
      00' WS6 Trans Am
      00' WS6 Trans Am
      Glad to hear you found the problem. Thanks for posting what you found.
      Tom
      Southern Indiana
      yeah WOT or high throttle opening will set most FI into clear flood shutting off injectors.
