      Mar 2010
      402 build, need advice!
      I've got a 67 Malibu (clone), 402 (3969852) with closed chamber -215 heads looking to build up and hopefully mate with a strong 700R4. After I complete my suspension would like to make her a runner, hence the 700r4...
      Does anyone think it would be worth it to build this engine up? I'm not sure if a 454 crank could be installed to bring it up to 427ci and possibly bored .060 over to bring it to 440.... the 402 currently is .030 over. Also, I currently have a large hyd cam, like the lopey idle.
      The heads... worth having work done to it? Ideally, I'd love to get 500+ horsepower, but not sure how well these engines perform, compared to the 454. Any info would help out alot... Thanks for reading!
      Mar 2010
      Central IL
      The heads aren't really worth anything they are from a 366 truck motor and have limited performance capability. Yes you can put a 454 crank in all of the journal specs are the same. Would have more torque than factory 427 due to the 4.125x4.00 bore and stroke vs the 4.25x3.76 of the factory 427.
      Mar 2010
      when I looked up the head numbers, they were supposedly off a 66-67 396 -427...
      Mar 2010
      Central IL
      Quote Originally Posted by GChamb2000 View Post
      I think maybe you looked at the wrong line or something cause I looked a few different places and it is listed as 366T they were listed in order by casting number.
      from http://www.mortec.com/bbc.htm
      3969852....366T......68-84...4-bolt
      3969854....396.......69......2 or 4 bolt
      edit:
      I just did a quick google search and found at least 20 places that listed it as 366 by just scanning the results.
      Mar 2010
      whoops! I feel stupid, I mean't to put down 3969854... thats what I get for posting this off the top of my head! But the head 3917215, is a 396-427 66-67 I thought. Any ideas anyone?
      Mar 2010
      Central IL
      I had a brain fart and didn't notice that the 852 number came up under block. Since I made the mistake I did a little digging and found out that the 68 L36 427 390HP used them so they aren't a bad head.
      With the advancements in cam design and intake/carb 500HP should be a piece of cake.
      Do you know if they have had hardened exhaust seats put in?
      If they haven't I would have 2.19/1.88 valves installed when having the seats put in for increased flow. Give them a port match, blend the bowls and polish the exhaust.
      Here is a decent little article on head porting.
      http://www.popularhotrodding.com/eng...ing/index.html
      Loganville, GA
      Personally I would get a 454 block, use your crank and have a 427 or so (depending on overbore) instead of stroking the 402 block. The bigger bore will let the heads breathe a bit better, plus I just like 427's.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Mar 2010
      Thanks LSx! I'm not sure they have hardened valve seats or not... right now I've got a hyd cam, pretty large (comp 286H) if I remember right. Love the sound and throttle response. Prior to that I had a solid lift cam in it when I purchased it and that was my fav. Would like to go back to that, except next time around will have to be sure to check valve lash a little more often!
    Tags for this Thread
