      May 2008
      Lynn Haven, FL.
      ? about body panel removal/replacement order
      I have finally got my 69 Camaro stripped down for panel replacement and know have a question of the order i should replace the panels in. I have the car bolted down to a cart to try and keep the structure rigid when I remove the rusty panels. The panels I will be changing are complete floor pan, complete trunk pan, both quarters, tail panel, and probably the outer wheel houses. I was going to do the complete floor first before moving to the rear section of the car. I have seen pics of other members resto's and they just cut out all the bad panels and reassembled the car with the new panels. I just want to avoid any saging or mis alignment issues as much as possible. So I guess my question is should I cut off all the bad panels at once or peplace certain panels in groups? Any ideas are appreciated.
