    Results 1 to 20 of 25
      Orlando, Fl
      Coilover bracket design
      Ok, looking for some constructive criticism. Preliminary design for an upper coilover mount. Will slot right into the existing frame. Factory upper shock mounts have already been removed.
      Looking for any and all comments.
      Nick DiPrenda
      Jan 2010
      Elk River, MN
      Looks good, but it's hard to say what's ideal without seeing what it will tie into. Have any models or pictures of where it will mount?
      Orlando, Fl
      Quote Originally Posted by monteboy84 View Post
      Matt, the second drawing shows some line traces. Those represent the frame itself.
      These parts are going to be sent to a rapid prototype machine this week and I will mock them up on the frame and take more pics later.
      Nick DiPrenda
      Jan 2002
      Italy
      Looks good,
      I closed mine a bit on the top as well to triangulate a bit
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      Auburn, WA
      I think it would be just fine, but I would widen the radius on the on the Y (vehicle-relative) axis side of the hole just a bit.
      I would also increase the area mating to the frame - although I can't tell how many linear inches of weld there will be. Is there a reason for the empty space underneath the brackets?
      Edit: I now see the coilover hole underneath. Is the brackets being welded to the UCA bracket as well?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Orlando, Fl
      Quote Originally Posted by silver69camaro View Post
      The brackets will be fully welded to the upright for the A-arm. The kickout on the inside is to follow the contours of the upright all the way down to the frame. Going to add a flat plate on the outer edge of the frame and brackets for the bump-stop to contact. The notches on the top of the brackets will lock under the lip of upright.
      Nick DiPrenda
      Jul 2001
      Calgary, AB
      It looks very similar to the original ATS (Stielow) design before they changed to the wider layout. IIRC there was some concern about the potential for deflection with the parallel configuration - I am assuming that you are trying to mitigate that with the low mounting point for the shock (?) One thing that I see with that (the low mounted shock) is that it could limit your shock length and that may be an issue with fitment if you're going to have a lower ride height. If I were to do mine over again I would go the oppoiste way and would have mounted the shock higher so that I could run a longer body and have more travel/compression at low ride height. Another thing that I would suggest checking is what clearance you will have at the upper end of the shock. Some of the adjustables, like the Penskes, have a larger adjustor at the top which is wider than the actual top of the shock:
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      Orlando, Fl
      James,
      That was the other option to go with the wider design. I am still not completely sold on the flat plate. I just wanted to get everyones thoughts. I have some prototype pieces from Lateral dynamics that I originally intended on using, but I think I can improve upon them.
      Nick
      Nick DiPrenda
      Feb 2006
      Phoenix, AZ
      Nick, was the LD bracket made of thinner guage than you plan to use as well? I thought I remembered it to be alot thinner guage than the ATS mount previously pictured.
      The ATS unit looks pretty bullet-proof.
      I would think the obvious (gusset the sides) but there's no room to clear the UCA. The only way I can think of is a semi-ghetto 1/4" thick bolt on cover for access to the shock top.
      I'm just throwing out crap to see what sticks or sparks your mind. I am far from a fabricator, just an chronic "overbuilder".
      You said any and all comments. Heh Heh Heh.
      1970RS Camaro
      Lateral Dynamics, Wilwood, BOZE, Strange Engineering, Alston, Ride Tech, Gen II, FAST.
      Dave Cozzi
      Orlando, Fl
      Quote Originally Posted by dcozzi View Post
      LOL. ALL comments. Hey, nothing wrong with some constructive criticism. The gauge of the LD brackets bothered me a bit. I want something a little beefier. I am going to combine ideas from my design and the ATS setup and will come back with a new 3D model in the next few days.
      Nick DiPrenda
      May 2002
      Northern California
      I believe both are(were) 3/16" but the LD had a longer span. Dipren, are you going to have a cage?
      Vince
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Orlando, Fl
      Vince
      Vince,
      I am not going to go with a full cage. I want to do a weld in roll bar to run harnesses and stiffen the uni-body.
      Nick DiPrenda
      Feb 2006
      Phoenix, AZ
      Vince
      Cool, the ATS just looks like 1/4" or bigger in the pic.
      Vince, you were born 1 day before me.....old man!
      1970RS Camaro
      Dave Cozzi
      Orlando, Fl
      Put the calipers on the LD mount earlier. 3/16th's ;)
      Nick DiPrenda
      May 2002
      Northern California
      LOL, but i look like im 12. haaa
      Vince
      Jan 2009
      Why the curved profile on the diagonal part of the bracket? I think you should just make it straight because the stresses and deflections will be less. I did a quick n dirty FEA on it to illustrate.
      Straight profile:
      FEA, straight on top, curved on bottom (this is the stress distribution):
      Sean
      Orlando, Fl
      Sean,
      The profile is curved for control arm clearance. I still may need to mod my brand new control arms, but trying to avoid it
      Nick
      Nick DiPrenda
      Jan 2009
      I wouldn't worry about it in either case. I was really just picking nits. The safety factor on it is really big anyway, I'm guessing 10+.
      Sean
      Feb 2007
      Kensington, Md.
      Hey I'm in the middle of a coil-over swap on my 68 Chevelle and like your design. I have a question on shock length, my plan was to use a 4.25 Varie shock w/ a max measurement of 14.25 extended length.
      What I have done so far though is to move my lower mount outboard about 3" with your design I may need a longer shock which also means a taller spring , from 9" to 12" to equal a 16" extended eye to eye. I think I will also have to Shave my frame to allow for clearence on the outside of the spring. I am currently using the 12" 5.15 travel Varie Shock on the rear of my car that I can use to mock this up. Any thoughts here, spring weight, travel ect ?
      Thanks, Tony
      New Lenox, IL
      Here is the setup I fabbed up for my 2nd Gen Camaro. I used the 6.150 travel VariShock and inverted the coilover giving free and clear access to the adjuster from the topside. The LCA is stock but modded with bolt in mounts for the lower coilover eye.
      Tom
      1980 Z28 Dk. Blue w/ Tri Blue Stripes
      Check out............
      firstgens.com Camaro Board
