      Jul 2009
      Digi-tails not blinking
      I have Spagetti front turn signals and rear tailights, all works but the blinkers. Here are the facts-
      -hazards work
      -with no load flasher in, rear blinkers flash very slow, once every 5 seconds, front do not come on at all
      -put the standard flasher in and hook up a test light to purple power feed wire that feeds blinkers and the front/rear blinker work fine
      Any ideas?
      is
      Jan 2000
      Thousand Oaks California
      What if you swap the slow flasher with the hazard flasher?
      Larry Callahan
      Jul 2009
      Figured it out. The flasher for the blinker had the power side going to the blinkers and blinker side going to power. Need to modify my fuse panel. Hope that makes sense.
