Thread: Panhard bar mounting design
03-14-2010 #1
Hey guys I wanted to run this by you. As you may already know I am installing a panhard bar in my car. With a panhard bar you need a mounting point for the frame, and you also need to brace this mounting point because the forces involved will twist the frame. My design is below, the mounts I am talking about are shaded blue...let me know what you think, good or bad?
Sean
03-14-2010 #2Looks like a solid idea. Maier Racing uses a similar idea on some of their kits.
If you can find it cheaper, I can fix it!
03-14-2010 #3
Starting The Transformation
- Aug 2009
- Langley BC, Canada
- 264
I am new to this stuff but trying to learn so correct me if I am wrong here. You will need to make sure you have enough clearence for the panhard bar to clear that brace as the rear will move front to back as the ride height changes? just a thought and as I said I am just learning so correct me if I am wrong.
Looks good though, Maybe a tubular design like the one twisted posted with your design would look nice and clean too.
03-14-2010 #4
