Results 1 to 20 of 23
Thread: Need new engine..
03-13-2010 #1
New to Pro-Touring
- Feb 2010
- Houston, TX
- 31
Need new engine..
over the weekend i blew my engine on my 69 camaro.
i added up the numbers and to rebuild/duplicate my current engine wont be worth the cost...
(im kind of starting from scratch now..except ive still got my 350turbo trans ..)
i was looking at the year one 350 crate engine (seems like most bang for the buck)..
any other suggestions? (like just bitting the bullet and getting an LS series engine?)
and also i will be using this car as a daily/weekend driver..so some sort reliability will be nice. (like you can even get any reliability..
03-13-2010 #2
- Apr 2008
- Newark, OH, / Concord, NC
- 497
Hot Rod,
What kind of power are you looking to make and what's your budget?, LS's are great engines, just make sure that you consider the total cost of the swap, motor mounts, headers, radiator and other issues, you probably can do the swap cheaper and with less labor by doing it with a Gen1 engine.
DaleIF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
03-13-2010 #3
- Apr 2008
- 497
I this is the Year One engine that you where refering to it looks like an awesome engine.
Performance » YearOne Crate Engines » YearOne Crate Engines » CT383PC1
Engine Specifications:
* Horsepower- 500
* Torque- 480 ft/lbs
* Compression Ratio- 10.7:1
* Recommended Fuel- 92 octane
* Max Recommended RPM- 6000
* Block- 4-bolt iron
* Crankshaft- Nodular iron
* Pistons- Forged with coated skirts
* Connecting Rods- Forged I-beam steel
* Camshaft- Hydraulic roller
* Valve lift (intake/exhaust):.463"/.570"
* Duration @ .050" (intake/exhaust): 238deg/242deg
* Rocker arms- Roller 1.5:1 ratio fully roller
* Cylinder Heads- Aluminum, hand worked
* Bore x Stroke- 4.03" x 3.75"
* Intake Manifold- Single plane aluminum
* Warranty- 12 month/12,000 miles
Part #DescriptionEmissions IDPriceAdd to CartCT383PC1 Year One Power Crate 383 engine assembly.
03-13-2010 #4
New to Pro-Touring
- Feb 2010
- Houston, TX
- 31
I havnt come up with a budget yet. im currently working on that. but my main aspect is lets say i pick up the CT350PC1 around 3k ..would it have been worth spending more or going with a different engine for the same price while im in the market for a new one ya know?
Thanks! ya my only concern with going with a gen1 ls..is that im tossing in alot of money as is for the mounts,headers,radiator,ect..if i do decide to get a ls series would it be worth getting a gen4 since im already putting in the parts for one? or should i spend that money i save with going with a gen1 on improving that engine? (sorry lots of questions)
as you can see im anxious to get the best for my dollar ya know?
as for power...nothing under 400hp..this is american muscle..i wanna keep those ricers far away and maybe take on some c6s (or at least give them a good run for their money)
03-13-2010 #5
New to Pro-Touring
- Feb 2010
- Houston, TX
- 31
03-13-2010 #6
