    Results 1 to 19 of 19
    Thread: trash in paint
      Oct 2007
      trash in paint
      For you guys with a paint booth..How the hell do you keep trash out of your clear?????
      OK, a little history.....got tired of having trash in my paint jobs, causing me to have to cut and buff everything, so I went to great expense to build a seperate shop, bought a reverse cross draft paint booth, and now after four jobs, am still getting fisheyes and trash particles in my clear. I don't seem to have the trash problem with the base coat, just clear. I have a brand new compressor with a refrigerated air dryer on it, air filters in the booth, and a filter screwed on the paint gun. I use a SATA JET 3000, Keep fresh intake and exhaust filters in the booth. I paint show cars, so doing the cut and buff is a necessary step anyways, but I'm just tired of this trash! I use tack rags and pads, have tried different brands, tried wetting the floors and walls, i wear a paint suit, gloves, head gear, tape up my sleeves, etc etc etc. I know my technich and methods are correct ( i think!), but can someone please tell me how you are keeping your trash out? Also, I know my booth joints and where it meets the floor are sealed properly and tight. I bring all my materials in the booth with me before I start, and I seal myself in till the job is finished, so I won't be going in and out of the booth while in process. I cut the fan off and let the pressure equalizem
      I use HOK products exclusivley, but I have tried Dupont products, and Martin Senyour products...same outcome.
      Please help!
      Tim
      TAJ Motorsports
      Dec 2007
      michigan
      Im not an expert painter, so take this for what its worth. Just some questions to answer that may put some light on some issues.
      But my guess for the junk is that is there in the paint as well, you just don't notice it as well as when the clear is there. Plus since the clear takes longer to dry, it has a longer time period to collect more crap that is floating in the air.
      How much junk are we talking about? I'm not sure you can ever get 100 percent away from it. If there is a large amount, then there is probably something wrong, but some is always there. At least what I've done and have seen others do.
      Do you have standing water on the floor while your painting?
      Do you have specific air lines for only spraying paints? Meaning, you don't use the same air lines for paint as you do for your air tools?
      Do you make sure all of your equipment is clean and wiped down.? Such as your hoses, gun, shoes, suite, mixing equipment?
      Is the car itself completely clean? Is there a possibility that you are stiring up trash that may have been trapped in crevaces?
      Sorry, I had more suggestions, but after re-reading your post, you answered them.... So Im not much help.....
      2005 CBR 1000RR..."mostly stock".
      1968 camaro... "in the works".
      Sep 2009
      Port Richey Fl
      This was from the SPI forum where the same question was asked. I sprayed yesterday in the rain and had the same problem in my booth. I don't wet the floor but I need to slow down my fan.
      One thing to check is air flow, too much??
      When spraying clear should have some over spray hanging in air for a little bit.
      Ground car, drive grounding rod outside, run coated wire into building I used a 2 Gage and hook to a jumper cable to clamp on frame.
      Chains to cement don't really do much.
      My feeling is dirt comes from car creases or gaps and masking paper if green type is used (real bad) and from the painter.
      I have shot black cars allover and not even cleaned the garage floor and had them come out clean.
      _________________
      [email protected]
      404-307-9740 cell, tech line 7 days
      706-781-2220 Office, Ordering 8-5 EST.
      706-835-5897 Fax
      This was another response from Texas
      humidity ? i watch my weather station real close now days. i shoot on dry days and no longer wet the floor unless it is a really dry day.
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
      trash
      I am no pro either, but in my experience, in a booth and my garage, I find it very important to use a tack rag between the base and the clear, and even in between base coats at times if you see dust nibs etc. When tacking, tack all the masking paper around the panels first, then tack the panels and proceed with the clear.
      Good luck
      Rockford Illinois
      You could try a different brand of filter at the gun. I have had several times in my life where filters had the insides not be made correctly and the crap from the filter material shed particals from them as they disintigrated inside. Remember that people work on those lines that make them even tho machines do all the assembly work and they have days they don't really care if things are going well and send the stuff down the line and out the door.
      Sounds like you are doing everything else right.
      Mar 2010
      Central IL
      In the shop I worked in part-time for extra precaution with customers that are known to be extra picky. We hung masking paper from the undercarriage to prevent/reduce undercar airflow which is were most gremlins come from when the booth and painter have been properly prepped.
      Jun 2009
      Pensacola Fl
      the car has to be clean. When you think it is clean , clean it again. Some trash comes off of you. We ware paint suits and clean the crap out of the parts/ cars. But we also use a positive pressure booth with heat which makes it nice. Tack between base and clear, sometimes we lightly sand between base and clear to get things out. Most every paint job has trash in it. Even with those precautions, we cut and buff everything as they are higher end cars.
      Feb 2003
      St. Louis, Missouri
      Every job has dirt in it...goes with the territory. Is the dirt the same color? Same size? Fibers? Any consistancy with the particles? It could be anything.
      Rick Butterfield
      Tulsa, OK
      Funny no one has mentioned dirt getting in when you mix and pour your product from cup to gun, a lot of stuff can get in during this process as well. Some guns offer a filter between the gun and spray head, but with clear they usually stop things up. Watch mixing your paint/clear and transferring it into the gun, leaving the gun uncovered even for a few seconds will allow contamination.
      1980 Z/28 383, Vortec heads, 2004R 342.1 powertrac
      1971 Firebird on rotisserie
      2006 Dodge Daytona Charger
      "Torred" # 1988 of 2000
      2013 Hot Wheels Edition 2 SS Camaro
      "I'm Not a Gynecologist, but I'll Take a Look"
      Jan 2009
      Jacksonville Florida
      do you have any overspray problems from clear drying too fast? I've seen trash problems and materials drying too fast because the fan speed was way too high, also if you have someone working outside the booth stirring up dirt around the shop
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Norway
      Country Flag: Norway
      Hoses
      And let us not forget one of the biggest sinners,old hoses.
      Smal particles of the rubber inside come of.
      Paintbooth hoses must not be used other places than in the booth.
      Do not drive over it.
      I use to change the hose after a year or two, then i bought a special hose from Sata.
      Still works :-)
      Arne A Hjemaas
      Oct 2009
      So Cal
      use a desiccant paint snake, and hoses for painting only
      Big Block Killer
      Jan 2007
      deland,fl
      for the most part i aways get a little trash here and there unless its a rainy day then the trash monsters dont come out to much.the fisheyes had a guy tell me before the he was having a problem with fisheyes it turned out to be his deoderant that he changed dont remember the brand but he seemed to believe that was it he said he switched back and never had the problem again.
      Oct 2009
      So Cal
      Are you sure its fisheyes or solvent pop
      Big Block Killer
      Mountain Springs, Texas
      You probably already know this but I learned the hard way not to use clear activator that has been open for any length of time. It absorbs moisture as the container breathes through temperature cycling resulting in fisheyes in the clear. Some guys shoot MIG gas into the can when sealing to extend the shelf life.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      toledo ohio
      let the car sit where you are going to paint it 100% ready to paint for about 24 hours. Make sure you have no air movement for that time and let the dust settle. Next day tack it off and paint do not blow it off and create more diert
      Jonesboro, Arkansas
      I know this might not be the problem but quite a few years ago (when I was painting) every time I clear coated a car the paint went on flawlessly. Next the clear coat, first coat looked good, let it set for a few minutes then went on with additional coats. After the first clear coat the next ones looked like I was painting with some kind of fuzz in it. It was in the summer, so naturally hot but what a fellow painter told me was since I had pre mixed all the clear I was going to be using it had started to set up! the fuzzies I was seeing was the paint starting to cure in the can. Started mixing only what was going to be used in the cup and never had the problem again. I had to learn though...
      Carl
      Carl Wilson
      Apr 2008
      Forest City,NC
      on the fisheyes i agree that the activator will cause them. close the can as soon as you pour from it,tightly. another thing i found that will cause fisheyes is deoderant,and any hair products etc that you wear,,even through a paint suit,,change brands and see what happens,or dont wear it at all,,,,,most trash will come from either the vehicle not properly cleaned,,jambs, wheelwells,around glass and any paper used for taping up,,and even with a paint suit,,you will still spread it from your suit,,, also if the floor is not wet,the air hose will kick up a fine amount of dust. good luck
      Mark Dorsey
      Jun 2009
      Madison WI
      we had to slow down the fan in my booth it was moving too much air and pulling in alot of dirt/dust from the shop and that was getting in the clear. not really a problem with the base but that dries so fast it would have not much time to collect anything. grounding the car and wetting down the floor has always worked well for me.
      on the fisheyes, i dont really have any suggestions on that other than use precleaner but im sure you already do. maybe ask your paint rep to come out and spend some time watching your usual routine and maybe he can see a fault that you are over looking. just a thought.
      hope you can figure out the problems.
      mike
