      Jul 2008
      Maple Ridge, BC,Canada
      Mini starter required?
      I was running a stock GM starter, it would get hot from the headers and not engage until it cooled down. A friend had a mini starter I could use. I put it in, but regardless of shimming, it never quite worked perfect. 30% of th time it would "clang" and not engage.
      I am wondering if I invest in a new mini starter or go back to the stock starter, but am concered about the heat issues.
      Engine is a .040 over 400 small block
      Block is decked and drilled for steam holes
      Scat 9000 crank
      Scat forged 4130 5.700" Rods, ARP 8740 Bolts
      Mahle pistons 10:44 compression
      Competition valve train
      Crane gold full roller rockers
      Competition Cam 284xe.
      AFR 210 Fully CNC Heads.
      Hogged out RPM Air Gap Manifold
      Custom 950 Pro Series Carb
      Thoughts?
      70 Nova - 406 sb -488 HP/504 TQ-3:73's
      http://s66.photobucket.com/albums/h266/steelratnova/
      Jun 2009
      Southwest Florida
      Swap in a remote starter solenoid and use the stock starter, lots of kits out there or you can hunt down the parts yourself.
      -- Dan
      Sep 2008
      Colorado
      I had posted a similar thread earlier and their recommendation was a high torque mini starter, 1 awg wire to the starter from the battery. My headers are also ceramic coated to help with the heat issues.
      Mike
