    Results 1 to 10 of 10
    Thread: L92 Cam
      Dec 2009
      L92 Cam
      Best L92 Cam with carb setup?
      Miamisburg, Oh
      it's the one that best matches the vehicle weight, gearing, cubic inches, intake and the intended use (daily driver, street/strip, etc)
      (hint: you'll get better answers if you can provide the above info)
      69 RS
      LS7, T56 and other cool stuff
      Back on track in late 2020!
      Build Thread
      Dec 2009
      67 Camaro, Drive on street but more autocross and track. Don't care if it's civil on the street, plus I kinda like a rough idle. No idea on weight, 67 Camaro with GW suspension, LS engine, TKO600, no sound deadening, no rear seats and front seats are recaros. 2 piece wheels and wilwoods. Maybe 3400? L92 so 6.2 litre from 08 escalade, Will run GMPP Intake manifold and holley 780 unless someone has a better suggestion
      Miamisburg, Oh
      That helps. Hopefully someone more knowledgeable than I will chime in here. There's certainly a lot of opinions on cams out there.
      All the cam specs I have in front of me are for LS7's but here are two and I think either one would suit you.
      .......................Duration................... ..Lift 1.8............LSA....
      Katech Torquer... 220...244..................615... 648... 110
      ComCams....XER...232...240...................633.. .640...110+2
      I would guess a cam between 220 - 232 duration is the right range for you since you probably want great torque over peak HP.
      I'm no expert, I just couldn't stand to see a blank thread.
      69 RS
      Build Thread
      Petersham ,ma
      call texas speed ...heres what i'm using on my lq4 6.0/ls3 head/vic jr intake build (very simular to your l92)
      http://www.texas-speed.com/shop/item...=1055&catid=44
      go over to ls1tech....lots of info there
      Dec 2009
      thanks!
      May 2008
      South Jersey
      x2 on LS1tech, lots of good info there.
      Nick
      '67 Chevelle 350/th350..... soon to be all aluminum 5.3
      '73 Chevelle 4.8/th350
      Dec 2009
      LS1 tech had some options, but only got me up to about 480hp. Getting a cam from Frank for $750 w/ springs to handle it that will put out 540 hp at crank. How awesome is that? I'm definitely happy with it for that price with that kind of gains. I'll let everyone know how it works on the dyno.
      Miamisburg, Oh
      we're waiting with baited breath for some specs man. don't be a tease!
      69 RS
      Build Thread
      Dec 2009
      You'll have to ask frank. I never got them. So maybe when I get it I'll get the specs. I'll let you know.
