Results 1 to 11 of 11
Thread: Help with Route to Completion
03-10-2010 #1
OK so I am pretty much on the last leggish as far as having a drivable project. Current things holding me up are mainly the last few parts of a wiring harness, gauge installation and a new top. The last obviously has to be done by a pro as im not looking to do a top install again ever.
Which leaves me with the wiring and the gauge install. For pretty much everything on this car i have just picked up along the way but without some real knowledge of what I'm doing as far as wiring goes I am almost at the point of just handing it over to someone to finish off the last couple connections.
So i have two questions really.
1. How much would an average shop charge to finish off a few connections on an AAW harness. Its all laid out just a few bits that im just unsure of where they go and so forth.
2. If it were you would you risk taking longer and not knowing if you are doing something properly or would you rather bite the bullet and get the car done much quicker then you could do it yourself?
I would love to completely do everything myself but without some guidance from a fellow gearhead who knows what they're doing im pretty much stuck with having to send it to a shop.
Chris Smock aka Blazed67
03-10-2010 #2
- Mar 2010
- Sparta, Michigan
- 41
That's a loaded question with tooo many variables... but if you were in my neighborhood, I'm pretty sure I'd be able to finish it off in a day an your bill would be less than $200 if everything was well prepped and not incorrect to the point you currently have it.
I can't recommend anybody in Tampa, but in West Palm - Errol can hook you up.
http://www.tpswestpalm.com/
03-10-2010 #3I was in the same spot as you last summer. Had my immobile Camaro in need of Wiring and a few other details. I employed Jake of Jake's Rod Shop to mop up those "few" details. I figured, well, if I am going to have someone work on it I might as well do front discs. and springs and shocks. and seat brackets. and wheels and tires. and a new gauge cluster. and throw the interior in. It turned out to be a much more involved and expensive project then I thought. I have to say, having a professionally wired car is awesome. It is artwork in itself and unlike my friends, ALL my lights work!
Bottom line, Jake did a great job, and my car is way, way further along then if left up to me. If you can resist the urge to go bananas, I say go for it.
They don't call 'em professionals for nothing.My candy dish is filled with razor blades submerged in Anti Freeze.
03-10-2010 #4
