    Results 1 to 9 of 9
      Sep 2009
      Proprotioning valve location
      I am running Wilwood 6 piston up front and 4 piston in the rear. I was wondering if the location of the adjustable proportioning valve matters. Does it need to be closeer to the master cylinder? or can I place it somewhere near the rear of the vehicle. This is on my 68 camaro. Any help would be appreciated.
      Feb 2007
      Vancouver, WA
      Anywhere in the main rear line - after the distribution block and before the split - would work. Mine is under the hood near the MC. I figured lt would be subjected to less road grime that way, but doubt that it would affect the valve.
      Jul 2009
      LBC
      The location does not matter. Mount it where you like.
      Sep 2009
      Thanks guys!
      Dec 2008
      Lehigh Valley Pa
      Would it be ok to mount one in the interior?
      1996 Federal Cadillac hearse
      1988 Eureka Chevy hearse
      So. Cal.
      I mounted mine at the line just to the rear of my seat. My line just happens to pass on the drivers side. I mounted it so the shaft of the adjuster knob goes through the floor. I think I removed the knob to keep the hole small. Then reattached the knob. So I can drop my left hand to just behind the seat and turn the knob while still seated in the car. I thought it would make it nice to be able to adjust the bias while seated in the car. Works good so far. JR
      Iowa
      Quote Originally Posted by JRouche View Post
      Might not be a good idea if you have kids that will ride in the back seat! Sorry, but that is the first thing that entered my mind. lol
      1980 Chevy Monza, 305/TH350 soon to be LS1/T56
      http://www.forums.h-body.org/viewtopic.php?f=20&t=26442
      Rustburg, Virginia
      Mine is mounted to a bracket that I welded to the floor just under the front edge of the driver's seat. I can adjust it on the fly, if need be.
      Auburn, WA
      If you can, mount it such the fittings are vertical - makes it easier to bleed.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
