    Thread: Timing tuning??
      Asheboro NC
      Timing tuning??
      having trouble adjusting the timing in my 383, its popping out of the exhaust when i give it a little gas, and puffing white smoke out too. the disributor is in the correct spot, all the wires are correct, sparks plugs are good, and i have an inductive style timing light. help me out please.
      Sep 2007
      Southern California
      If you pulled the distributor, are you sure that you don't have the distributor 180 degrees off?
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
      Asheboro NC
      Quote Originally Posted by Roadbuster View Post
      yep! shes dead on post #1 on 1st cyl TDC, just cant get the timing right . idk wich direction to turn the distributor
      Sep 2007
      Southern California
      On a Chevy, counterclockwise advances the timing; clockwise retards it.
      See this article: http://www.chevyhiperformance.com/ho...673/index.html
      Jon U.
      Build Thread
      Asheboro NC
      sweet, also i have an MSD digital 6 box, ive heard they will make a timing light read wrong?
      Sep 2007
      Southern California
      Quote Originally Posted by slownova73 View Post
      Can't help you there. I run a HEI on my car and don't have any experience with MSD boxes.
      Jon U.
      Build Thread
      Mar 2002
      North California
      Unfortunately the dial back/digital timing lights cannot read the signal under 3000 RPM because you are getting 2-3 sparks for each cylinder.
      The problem at higher rpm's is that it is still 1 spark, but it's a longer duration spark.
      The dial back timing lights usually will not give you an accurate timing readout regardless of RPM.
      MSD recommends a basic, no thrills or frills,inductive pick up timing light and your timing issues will be just fine.
      Good Luck!
      -Jim
