    Results 1 to 15 of 15
      Crown Point, Indiana
      Broke my new Shockwave!
      Not to much driving right now. I had a minor set back when I pulled into the garage I saw a little oil coming from my front Shockwave.
      As I looked under the car I noticed It had broke or something.
      After I had got the car onto the lift I could see it was devastating.
      It looked like the shock had split. After talking to Jeremy at
      ridetech, he informed me that, that is where the lower half of
      the shock screws to the body.
      He told me that they will get to the bottom of this and I should return the Shockwaves and LCA to them so they can inspect it up close.
      I would just like to go on record that I have been dealing with air ride Technologies (old name) since Ridetech (new name) 2000 when I bought my first suspension for my Nova, and I will continue to purchase from them. The service and especially the customer service has been 125% Top notch!! You have to remember this is new technology and there are going to be some "bumps" in the road!
      Sep 2009
      I just installed some of the newer shockwaves, hope it is not a flaw in the design. I will agree though, the company and customer service is first class all the way.
      Jul 2008
      Bethlehem PA
      PLEASE Keep in Mind Just MY Opinion from what I See in the Pics.
      I could be :bsjerk:
      Looking at the pics, the problem seems to be lack of clearance between the shock mount and the reinforcing plate on the a-arm. When the suspension compresses, the plate pivots up and contacts the shock mount, and acts like a prybar against the shock, right above the shock mounting bolt, causing the shock to bend and pop out just as it did in the pics. You can see the damage to the shock mount on the left, just above the bolt hole (pic 3). Good news would be it would be Not a defect in the shock, and probably an easy fix.
      Good Luck with it !!
      John at SC&C
      Savitske Classic and Custom
      NEW # 610-381-6100
      '87 Buick Regal Turbo T - Since New
      Lots of SC&C, Fays2 Watts Link
      Boze Pro Touring wheels,
      Baer 13" Pro+ & SS4+
      Shaved door handles
      Custom S/S Exhaust
      san diego
      Quote Originally Posted by T-CHRGD View Post
      I could be :bsjerk:
      I agree, whos LCAs are those?
      Quote Originally Posted by falcon65 View Post
      ridetech's LCA's
      san diego
      well it looks like the LCA hits the shock under compression. Are your bumpstops setup correctly?
      It wasn't the bump stops the LCA could not go past 80* at which the lower part of the shockwave hits the webbing on the LCA. and after talking talking Jeremy @ ridetech they will need to redesign their LCA so I will need to ship the front shockwaves and my LCA's back to them. Another note on customer service when this happened the next day my wife called Jeremy and told him that we had a leaky shockwave and he immediately had one built and shipped overnight. Although this was not going to fix this problem I was amazed, that is over and beyond what I had expected.
      Central Florida
      Jeremy is . He helped me work out a couple of controller issues i had on 62 caddy i'm building. Their service is first class, i'm looking forward to my next ridetech install.
      BB
      So. Cal.
      Interesting. I have shockwaves. I re-worked my lower control arms (MII arms) to fit them. I moved the suspension throughout the entire movement after welding in my brace plates on the CA. And I did have to clearance the inside of the plate to clear the lower part of the shockwave body. Actually it was to clear the adjusting knobs of the shock, not the body. The clearance between the plate and the shock housing is very close on your vid. Also, in the vid it didnt look like the plate was bent or even that the paint was removed. No signs of contact. But the way the shock is broke and the close contact area looks to point at that interference.
      You had the old shockwaves on before. Did you replace the lower CAs with the new shockwaves? JR
      No, the older ones worked for 5 years I upgraded to the Master Series and they redesigned the shock. The LCA are old airride tech musII but they do not work with the new design. And the newely designed LCA do not work either.
      san diego
      Jun 2009
      Pensacola Fl
      ridetech has a very good product and good service. Glad to see this was taken care of.
