      Sep 2007
      Denver
      coating exhaust welds
      I am about ready to get my headers and collector coated with ceramic. I have a magnaflow stainless setup to go with it. Question is if I ceramic coat the collectors before welding exhaust and need to remove coating first how do I keep uncoated welded portion protected? My thought was to get collector welded to first portion of stainless and take to coater and have ceramic coated including weld.. does this make sense?
      If it matters my collectors have the V clamps welded on.
      David Beckstrom DVM
      Aug 2008
      Pgh, PA
      It makes sense. I did all my exhaust fabrication and welding, then unbolted and took the finished product to have it silver ceramic coated. Worked out great.
      Mar 2004
      Mid-Michigan
      Weld a short piece of tubing to your collectors, 3 or 4 inches long should be plenty, then send them out for coating. When you build your new exhaust simply bell the pipe for a slip fit over your "collectors" and clamp in place. No welding on ceramic required.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Sep 2007
      Denver
      I have little exhaust exp but noticed that the custom/higher end builds get welded vs slip /clamp treatments. I think you have a good idea about the slip fit but.......thanks for the reply
      David Beckstrom DVM
      Aug 2008
      Pgh, PA
      Look at https://www.pro-touring.com/forum/sh...56&postcount=4
      Pics of exhaust TIG welded and then ceramic coated.
      NC
      Quote Originally Posted by Denvervet View Post
      Most high end exhausts use V-band clamps.
      Having some sort of bolted/clamped connections make for easy of installation as well as disassembling the system if need be.
      wmhjr,
      Thats a very nice set up. I like the oval tubing, looks sharp.
