Thread: Opinions on my setup
03-03-2010 #1
- Aug 2004
- Milwaukee, Wi.
- 327
I have a 69 Nova with factory replacement front discs and I just installed Explorer rear discs. I also have a 1-1/8" bore Chrysler mc and Wilwood's new 5 port, adj. prop./ comb. valve. I am going to be running this setup manual. I want to run 3/16" lines front to back too.
This is a street/strip (800+ hp) car.
What do you guys think?
Thanks, Steve6
03-03-2010 #2I think a 1" or 15/16" bore MC will better work with a manual setup mainly because pedal effort will be reasonable. I also think an adjustable prop valve (not a combo valve) will better suit your setup with a bit of tuning adjustment. Brake line size will not affect your brake performance so 3/16" is fine.
03-04-2010 #3
- Mar 2005
- 345
To add to what NOGO posted, you may even need to go to a 7/8" M/C. Best bet is to measure the bore on a front caliper to get an idea of the piston area. That will give you a better idea of what size M/C is required.
Bob.
03-04-2010 #4
