    Results 1 to 11 of 11
    Thread: Paint question
      Houston, TX
      Paint question
      Can I use one brand of primer and spray another brand of base and clear on it? I'm getting ready to paint my 67 Fibrebird project, and I'm thinking about using House of Kolor primer with PPG base and clear.
      Any information is greatly appreciated.
      Thanks.
      Tu Ho
      Firebird V2-LS swap
      Feb 2003
      St. Louis, Missouri
      I've done the opposite and it worked fine. You'll more than likely be ok.
      Rick Butterfield
      Aug 2006
      Belforest, AL
      HOK primer is expensive. Why wouldn't you just use PPG's lineup of primers?
      But to answer your question, yes it'll be fine.
      Todd S.
      "I like to race school buses..."
      Houston, TX
      Quote Originally Posted by LateNight72 View Post
      I spoke with the paint supplier today about HOK primer and he did said that HOK primer is expensive and designed more for their top coat. He recommended U-poll or Valspar. PPG primer is about $360/gal vs. $200/gal for Valspar.
      Tu Ho
      Firebird V2-LS swap
      Mountain Springs, Texas
      Quote Originally Posted by rickpaw View Post
      You should check out the SPI (southern polyurethane) primers. Good quality for a good price and free shipping if I remember right.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2009
      Jacksonville Florida
      it'll be fine, but I still don't see a reason using hok primer,just use PPG
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Aug 2002
      Waleska Ga.
      Don
      I 2nd the SPI all of there products are top notch an reasonably priced.
      David Sloan
      Middleton, Wisconsin
      Pick the paint system you want and use the product from bottom to top, that way if there is a problem the company may warranty it. If you put down HOK primer and topcaot with PPG and for some reason you have a failure neither brand will back their product. Automotive paint is a system pick brand you like and use it!
      Ron B - 1966 Ford Cortina work in progress. 5,0HO, T-5, 8inch with 3.00s, Megasquirt ECU, rollin'on 52 inches!
      Houston, TX
      I bought a gallon of U-Pol S2025 direct to metal 2k primer. The plan is to primer the car in U-pol, and top coat with PPG color coat and clear.
      Do have another question though. I mixed the primer per instruction for primer sealer (4:1:1) but the paint came out in splatters with orange peels. I used a deVilbliss startingline primer gun with 1.7 mm tip. Should I thin it some more?
      Tu Ho
      Firebird V2-LS swap
      Ramona, Ca. San Diego area
      I have that gun also and I use to use it to spray primer with it and hated it!! You have to reduce it with acetone to get it to spray. It's not you, it's the gun. Toss it out and buy an Iwata LPH400. You'll be very happy with it. I use it to spray everything from primer to base and clear. Lays perfectly with out orange peel. Just make sure you detail the gun after each use.
      67 Camaro convertible (Jinx)
      Houston, TX
      Quote Originally Posted by 67 ls1 vert View Post
      At $400, that Iwata is WAY out of my budget. I'll try to thin it out some more.
      Thanks.
      Tu Ho
      Firebird V2-LS swap
