Results 1 to 7 of 7
02-25-2010 #1
- Jan 2010
- Elk River, MN
- 676
EFI pump - Regulate to carb pressures?
Okay, so a little back-story - My Monte Carlo has a stock fuel tank and pickup for the stock carbureted mechanical fuel pump. When I swapped in the Vortec 5.7, I had to install an electric fuel pump, as the block has no provision for a mechanical pump to be installed. Not knowing better, and being broke, when I dropped the motor in, I used a little Carter pulse-type fuel pump. I burned up one a few years back and replaced it no problem, but now as I get it back on the road, I really don't trust that pump.
So, for now, I would like to replace it with something more reliable, preferably a Grand National tank and stock Grand National fuel pump ~50psi. I want to do this since it's what I plan to run when I swap in an LS motor next winter. Problem is, I want to run it with my 650 Demon carb for this summer so I need lower ~7psi fuel pressure.
Can I run the 50psi pump with a return-style regulator to achieve the 7psi I need, without harming anything? The regulator would be on the frame rail near the tank, so the return line would be short, as well as the high-pressure line running from the pump to the regulator.
ETA: I meant to put put this in Carburetion, but I guess it applies here anyway. Mods, feel free to move it if need be.Matt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
https://www.pro-touring.com/showthre...ng-Bertha-Back
http://ls1tech.com/forums/conversions-hybrids/1499192-84-monte-5-3-build.html
https://www.pro-touring.com/threads/...rvette-Racecar
