      Aug 2008
      new braunfels, tx
      FirstGenZq8: test
      engine
      LT1 355 c.i.
      mahle pistons/rings 11.5:1
      5.7HP rods w/ bushings
      king rod/main bearings
      cam bearings
      M155 oil pump
      LT1-LE1 head/cam package: stock valves w/ back out, 195 CC intake port,
      CRN-10308-1 valve springs/retainers/locks
      GM lifters 12499225
      COMP pushrods CCA-7808-16
      COMP Cams Magnum 1.6 rockers CCA-1305-16 (7/16 stud) use w/ ARP-134-7103 (7-16” studs)
      trick flow TFS-30400623-8 guide plates
      sealed power gasket set
      ARP Cylinder Head Stud Kits ARP-134-4001
      ARP Main Stud Kits ARP-234-5601 (w/ windage tray)
      ARP connecting rod bolt kit ARP-134-6005
      Avon Automotive Progear Timing Chain #4145
      polyurathane motor mounts
      ASP underdrive pulley ASP945103
      cooling
      Summit Direct Fit Aluminum Radiators SUM-380473
      flexalite 210
      JTR cooling tee
      AC delete
      CSR electric WP
      intake
      tfs-3150800 trick flow air inlet elbow
      gp-sorensen TB gasket pack 96-3008
      exhaust
      LHT longtube headers
      percy's header gasket PHP-66031
      !cats
      3” dual exhaust
      x-pipe
      magnaflow 14419
      electrical
      vented optispark swap
      MSD 8.5mm wires
      fuel
      30# injectors
      aeromotive FPR
      chassis/suspension/brakes
      2" spindles
      hotchkis springs
      PST swaybars
      prothane total kit
      GTA steering box
      zq8 frame brace
      Z06 13” front brakes
      LS1 rear brakes
      LS1 rear brake pads
      renzfab ebrake brackets
      SS F/R brake lines
      ground force 3 in mono leaf # 2010
      steering shaft
      boosted bars
      lowering blocks
      axle set back plates
      howe tall upper/lower ball joints
      tubular LCAs
      tubular UCAs
      front coilovers
      wheels/tires
      ZR1 wheels w/ 315/35/ZR17 & 255/40/ZR17 KDW's
      skulte 2” adapters for rear wheels
      315/35/17 tire height=25.68"
      255/40/17 tire height=25.03"
      T56
      first gen 5 speed pedal assembly
      CNS-SC126869 coni-seal clutch slave cylinder
      CNS-CM126857 coni-seal clutch master cylinder
      BYUNSPEED short shifter handle
      ctf-df039020 centerforce dual friction clutch
      a7721 corvette lower shifter boot
      51799 corvette upper shifter boot
      motormite pilot tool 14523
      motorite pilot bearing 14650
      engine dress up
      grille insert
      accelerator linkage cover
      Mr. Gasket Master Cylinder Cover MRG-4573
      made for you wire looms MFY-5035611
      exterior
      bravada grille
      grille: Carriage Works 40053
      rear
      www.tomsdifferentials.com
      208-265-8111
      2000 8.5
      Eaton HD Posi – page 45 in their catalog part #8.5-EP30
      richmond 4.10 gears R8.5
      billet 3R yoke #8.5-TYBY $120
      forged yoke #8.5-TFY $90
      summit aluminum diff covers
      jegs aluminum diff cover
      http://www.jegs.com/webapp/wcs/store...10002_14600_-1
      Aug 2008
      new braunfels, tx
      Aug 2008
      new braunfels, tx
      WTB, but not needed
      underhood
      longacre magnetic drain plug
      radiator cover
      stainless steel radiator support
      LT1/4 starters
      wheels/tires
      gorilla wheel spacers $5.99
      wheel spacers MM816449N
      lug nuts:
      scratchless sockets
      scratchless sockets 2
      lug nuts
      lugnuts 2
      lug nuts 3
      chassis/suspension
      c notch
      driveshaft loop
      a-arm spacers
      longacre a-arm spacers
      interior
      shift light
      grant steering wheel GRT-1471
      horn button
      interior
      custom head unit mount kit
      ram mount
      window motor replacement
      window motor replacement 2
      center vent mod: http://www.syty.net/forums/showthread.php?t=57762
      iTouch as head unit
      iTouch as head unit 2
      T56
      shift knobs
      shifter boot
      jegs 2” shift knob
      skip shift eliminator
      exterior
      tonneau cover
      toolbox YH279318
      s10 sunroof
      spoiler support 1
      spoiler support 2
      spoiler & hood supports
      dzus fasteners
      bedliner
      LeBra Low-Profile Tonneau Cover Systems 93-90103-01
      door seals
      spoilers
      plastic sheet
      aluminum sheet
      spoiler support
      spoiler hinge
      black spoiler
      clear spoiler
      dress up
      intake dress-up
      miscellaneous stuff
      windshield wiper removal
      aiming headlights
      http://shbox.com/1/4th_gen_tech1.html
      wheel calculator
      BOSS GLOSS
      civic filter
      summit tie wraps
      hardware organizer
      window guide repair
      LMC bulk order:
      tailgate parts
      fender arches
      headliner
      headlight parts
      turn signal parts
      taillight parts
      miscellaneous mods
      mesh: 1 2
      hammock
      aluminum driveshaft - 99 TA - 4L60E - 41 inches long center of u joint to center of joint.
      LT1 nitrous
      RACING
      driveway austin
      big bend open road race
      harris hill roadcourse
      Aug 2008
      new braunfels, tx
      Over The Valve Cover wire lengths:
      1. 29" _ 2. 30.5" _ 3. 33" _ 4. 33" _ 5. 37" _ 6. 41" _ 7. 41" _ 8. 40.5" _ C. 10.25
      As measured BETWEEN the boots.
      RUS-648080 -6 AN to 18mm X 1.5 O-ring $11.39
      RUS-620411 -6 AN 45* powerflex hose end $15.95
      High pressure Input from Hydroboost Output
      RUS-648060 -6 AN to 16mm x 1.5 o-ring $7.69
      RUS-620421 -6 AN 90* hose end $13.95
      Pump High pressure output to Hydroboost Input
      25" 3/8 Low pressure return line
      3/8 Brass "T" for connection
      RUS-648050 -6 AN to 11/16-18 in. inverted flare fitting $10.95
      Hydroboost Input from pwr steering pump
      36" SS Braided High pressure Teflon Line
      RUS-640380 -6 AN to 5/8-18 in. flare fitting $4.95
      Hydroboost High pressure Output to steering box input
      27" SS Russel Braided High pressure Teflon Line
