02-21-2010 #1
AIR RIDE HELP!! Solenoid stuck OPEN?
Hey everybody, I need your help as fast as you can provide--The solenoid on my ridepro e2 seems to be stuck in the open position, and is thus leaking air into my bag constantly! I'm super-concerned that I could end up blowing a bag. Does anybody have any ideas or advice? Here's a detailed list of what's going on:
--started the car, set to ride height.
--right rear bag continued to inflate.
--deflated, right rear bag immediately reinflated.
--shut car down, right rear bag CONTINUED to inflate!!
I can deflate the bag manually, but as soon as I deflate it, it starts to refill again. The only solution I can think of is to just keep airing the bag out without letting the compressors kick in to purge the system--but that's clearly a bandaid fix.
02-21-2010 #2
New to Pro-Touring
- Dec 2009
- warsaw Indiana
- 8
I have had a similar problem there are 2 things to do
take the magnet off of the solenoid and remove the valve post to make sure there is no debris causing it to stick, clean it up use some light weight oil or spray lube and reassemble
MOST LIKELY you will need to call Brett @ ridetech though because the problem is in the electronic control box a diode problem or something like that. They will send you a new box or repair yours.
but take it apart first so you can diagnose the unit
02-21-2010 #3
