    Results 1 to 13 of 13
      Dec 2009
      QUESTION: PROJECTS UNDER $2k?
      Here's a question dedicated to all of us "broke" guys working a piece/project at a time...We all know the build as a whole could make a grown man cry if he added up the receipts. So, what single projects within your build would come in under $2000?
      Kevin Matthews
      My ride: '71 Buick Riviera named "Delilah"...because she drains me of energy and I had hair when I bought her...
      AIM HIGHER, DIE TRYIN
      St.Anne Il
      the wheels on mine..lol...um unless you got it for free im sure it cant be alot..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Rockford Illinois
      You need to pick up a copy of the latest Grassroots Motorsports mag and see all of the cars that ran for the best under 2k. It's a great article and lots of amazing and not so amzing cars.
      There were several 12 sec. cars for that money if you can believe it!!
      Oct 2009
      The current build I'm doing right now is going to come in at about 1800 : ) Price of car and paint included. 83 Regal
      Dec 2008
      Miami
      classic auto air and front suspension on my c10..did all the labor my self..
      "Get your facts first, and then you can distort them as much as you please"
      Feb 2002
      Springfield, MO
      Most everything on my car was Done in less than $2k incraments. Obviously not the paint tho.
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      west michigan
      Quote Originally Posted by shmoov69 View Post
      same here. doin a budget 4 link right now under 2k. just got done with the front suspension with new upper and lower a arms and coilovers ats steering box for under 2k
      Chad Read
      Oct 2009
      Copperas Cove, TX
      I think my interior came in at less than 2k or close to 2k. Maybe.
      Andy McCatherine
      1982 Monte Carlo SS (clone)
      Southern Indiana
      Hoping my Caprice and Monza keep budget reasonable:
      Monza: Traded for
      283 SB free with bearings
      double humps, almost complete Traded for, still need retainers
      LT1 FI intake
      5 lug conversion, off old Monza
      Megasquirt ?
      Trans off the shelf
      Wheels ? Corvettes with adapters from ebay?
      Tires ?
      Radiator, maybe off ebay????
      May do S10 rear disc conversion, 200 a side 400 total
      Now have God know how much in new tools like new welder costing money!
      Caprice,,,traded.
      Big block off the shelf, trans too, but may upgrade to Switch Pitch
      Kore 3 brackets 85 front 85 rear so $170
      Caliper kit off ebay $385
      Rotors $55ea $220
      Wheels $649 18x10 18x9.5
      HMMM not sure on sound systems or interiors
      Paint for either probably not over couple hundred each
      Dec 2009
      Sweet. I figured I could do most individual operations for about that. The body/paint is gonna kill me, probably the supercharger, and MAYBE the wheels...why? Because I picked some Forgelines that cost far more than my second and third choices (which include Fesler). Why do the Forgelines cost so darn much? Anybody know? I mean, Fesler and others seem to be as reputable but cost less...
      Kevin Matthews
      My 3 link is falling under $1200 https://www.pro-touring.com/forum/sh...ad.php?t=61592
      My Wheels and tires
      $360 4 wheel disc big brakes http://www.chevelles.com/forums/show...=115940&page=4 post #51 has my parts list
      406 came in at $2500 thats full roller valvetrane aluminum heads etc.
      Jun 2009
      Southwest Florida
      I'll be itemizing my upgrades at or below 2 grand for alot of stuff, mostly because of time constraints. I plan on making the car my regular ride, and a downtime of more than a weekend isn't gonna work out. I was kind of surprised at how many things can be broken down that way, other than complete engines, transmissions and fancy moser/strange/etc rear ends there's not a whole lot that costs over 2 grand all at once. My project is a 1975 firebird that I'll be picking up in a couple weeks.
      So in some vague semblance of order that I'll be doing them in....
      Manual brakes: Not quite sure on the cost, but I'm sure if I do my homework before spending a dime it could almost be done for free.
      Performance brake pads on stock disc/drum brakes: 100 dollars
      Mild sound deadening(spectrum undercoat, a bit of damplifier and heat shielding where needed): ~250 dollars
      xpipe exhaust + hooker aerochamber and resonators: under 1000
      1970-73 trans am front nose swap: ~400 dollars
      Modernize and rewire electrical system, hella headlights: under 1000 dollars
      Temporary repaint(rustoleum satin black or maaco): Under 500 dollars
      Subframe connectors and solid body bushings: under 400 dollars
      Delalum bushings where appropriate: ~500 dollars
      Hotchkis TVS kit + 4 matched shocks: ~1900 dollars
      B&M megashifter & leather steering wheel: 500 dollars
      Rear end: if the stock posi works, won't be doing anything to it, but if not, it'll be moved up to first on the list, and rebuilt with new gears and a truetrac+ axles: 1200 dollars.
      Prep for efi (stainless efi tank+pump, fuel lines, regulator to use with carb): 1200 dollars
      Multiport EFI install, edelbrock efi manifold, injectors, and ez efi mutliport system: Should come in under 2k with room to spare.
      17~18 inch rims and tires: Setting the budget at 2k tentative, but if I find a set of rims I JUST HAVE TO HAVE it could go a smidge over.
      Kore3 C5/6 front and rear brakes: Depends on whether I go for the zo6 setup or not, but the basic C5 brakes front and rear should run under 2k for my
      application.
      The I'll finish off the suspension with tubular upper and lower control arms: 1700 dollars
      After that it's pretty much the high dollar stuff that I don't wanna skimp on, giant cupholders, a stroker engine build, bowler 4l65e overdrive, maybe a moser wavetrac 12 bolt rear, the "real deal" final bodywork and paint job.
      -- Dan
      Dec 2009
      ri
      my dash and gauges came in way under 2k ( made dash myself)
      my 06 GTO seat set was only $650
      brakes- new booster, new master,prop valve, discs up front, around $800
      vintage air heater a/c unit $1200
      wheels and tires- old school Rally II
      steering column, wheel, linkage $600
      new Painless wiring chassis harness $550
      windows all around about $900 (lots of ebay )
      new posi carrier and rear end gear and rebuild kit $800
      items NOT under 2k: 04 LS1 with 6 speed, global west suspension w/QA1 coil overs,body and paint,
      of course I am not charging myself labor to do any of this stuff if I was none of it would be under 2k
