      Wichita, KS
      What Amp Relays Are Needed For H4 Bulbs?
      I am putting in 100/80watt H4 bulbs. I have a wiring harness kit for the H4 lights already but one of my relays is messed up. I need to replace the relays and want to know what Amp Relay I need to make the H4s work properly.
      Brian
      Feb 2009
      muggy midwest
      If you want, I have several HD70 amp SPST relay kits-I build mine as needed. If you want one, they are $59 each and I build them myself from Delphi spools...OEM rated stuff-not cheapo parts store wiring.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Feb 2007
      USA, TN
      100 watts * 2 = 200 watts / 12 = 16.66 amps. A standard 30 amp relay will do the job.
