Thread: fuel line plumbing
02-18-2010 #1
- Feb 2010
- 3
fuel line plumbing
i have a 670 street avenger carb, can someone help me on which parts to use to go from the stock GM fuel pump to this carb, i would like to have the line go from the pump to a fuel filter to the dual feed line that i need for the carb, unfortunately i get to confused by all the numbers and i dont know what will thread onto what, i think i might go with this setup and would like to know if it will work. how would i attach a fuel filter to that?
this feed line for the carb:http://www.jegs.com/i/Russell/799/641090/10002/-1
and this line from the pump:http://www.jegs.com/i/Russell/799/641030/10002/-1
will this fuel filter screw right in inplace of one of those adapters? http://www.summitracing.com/parts/RUS-650133/
02-22-2010 #2It appears that the fuel line that you want to use coming from the fuel pump has a -6AN outlet fitting. If this is so, it will interface with the filter you selected with no problem.
As far as the dual feed line, it has a 3/8" NPT inlet, which will not interface with the -6AN outlet on the filter. You will need this adapter to go from the filter to the dual feed line:
http://www.jegs.com/i/JEGS/555/10033...ductId=1284108Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
