    Results 1 to 12 of 12
    Thread: More Mopar ???
      Jun 2005
      Stillwater Ok
      More Mopar ???
      I have done a lot of searching here on Mopar suspensions and there is a lot for early B Bodies (74 and Older) A bodies up to 76 and so on. But very little on the forgotten B Bodies the 75-77 Charger-Fury 75-79 Cordoba and the 78-79 Dodge Magnum.
      I seen where it was mentioned several times that the K member could be beefed up by welding and gusseting. Where are those points at?
      Also what is the best way to strengthen the LCA?
      I have both the Cordoba and Magnum GT and the Magnum is my project car so it will be my PT car on a low end budget. A little info on the GT
      400 B block engine
      727 Lock up trans ( I hope to change it to a 5 Speed)
      The rear is unknown for now but I look to put in a 8 3/4 SG rear with 3.23 gear set
      Any suggestions will be helpful.
      Jun 2009
      I believe FFI carries stuff for the later 70's stuff. Good luck, your best bet may just be really well tuned stock stuff.
      Dan W
      1968 Plymouth Road Runner
      1962 Dodge Dart 440
      Jun 2005
      Stillwater Ok
      True there are some really good parts out there I have found. I just need to learn where to modify the K member and the LCR.
      I can get heavier Torsion bars and leaf springs. And Aluminum mounts for the K member and Torsion bars. The rest I will have to I will need to make up as I go along like sub frame connectors and stuff.
      Junkyards here I come.
      Jul 2009
      Grand Rapids, MI
      You may want to connect with Bill Reilly at Reilly Motorsports a cool. He's done some one-off stuff and his website is also NOT complete with all his goodies so maybe he has something OR can point you in the right direction.
      Will Ellis
      Build Thread
      Jun 2005
      Stillwater Ok
      I am looking to improve on what I have. And the AlterKtion he has is out of my reach for now.
      Jun 2005
      Stillwater Ok
      Quote Originally Posted by wellis77 View Post
      I called Bill Reilly like you suggested and had a nice short talk with him. He has a kit for my car which is great, he will be putting it on his website soon.
      This will make it easier to go in the direction I want to go in with my car. Thanks wellis77
      Colorado Springs
      K frame mods would consist of welding up the seams and adding gussets to the steering box area.
      Lower control arm boxing plates are available from Firm Feel and Mancini. However, I've got a set I've never used I'll sell you for $20.
      Shocks are a concern though as there is limited aftermarket choice for these. In the rear you can convert to a non-iso set up using traditional shock plates and use earlier B shocks. Up front, you have to get creative. After gusseting, you can open up the top of the control arm to allow shock body access and use earlier B body fronts or you can punch through the top and bottom plates and use 1st gen Camaro shocks.
      Subframe conenctors are just 2x3x.090 square tube you weld. $20 at a local metal supplier.
      What else are are you after?
      TonyC@HP2
      Jun 2005
      Stillwater Ok
      Quote Originally Posted by High Plains Mopars View Post
      PM sent. Thanks for the tips that will get me going in the right direction.
      Colorado Springs
      Here are the shock set ups in my mopar F body, which are similar to your magnum. This is the camaro shock arrangement up front and the non-iso clamp rear set up.
      TonyC@HP2
      Jun 2005
      Stillwater Ok
      Thanks I know what to look for.
      Jul 2007
      Tracy, CA.
      You can try this site as well http://www.forbbodiesonly.com/
      maybe there will be some discussions for you...
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Jun 2005
      Stillwater Ok
      Quote Originally Posted by class67 View Post
      Only if you have a older B body and into restorations great people there.
