02-17-2010 #1
Need help with right side lights 69 Firebird
Having trouble getting power to right side tailights and headlights, checked fuses,all look ok, left tailight works fine,it appears that right tailight harness is tied in the same spot as the left and yet the lights have no power, do these cars have some tricky ground? My test light will not light up when grounded to the body while hitting the positive wire on socket that has power. This makes no sense.
Thanks in advance
Do what's right,not what's easy
69 Firebird
71 Cuda
98 Supra 6speed white APU
98 Lexus GS400tt widebody
Elite Custom Body
Stefan B.
02-17-2010 #2
- Nov 2008
- Long Beach CA
- 64
I have very little experience with these things...just my .02
You should not have a positive voltage at the light unless it is on, and then you should have positive on both sides of the light.
I think you need to look closer to the switch and the fuse block. Isn't there multiple grounds there that need to be attached?
There are some smart cats here...I will be looking for the answers too! Good luck
02-18-2010 #3I believe that one of the rear circuits (either the brake or tail) grounds through the socket itself, via metal prongs. Correct me if I'm wrong.
Have you visually inspected the wires which lead from the left tail to the right tail?Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
02-18-2010 #4so far what I see,is there is a cable going from left side under the seat and into the trunk ,then two sets of wires spliced into it for left and right tailights,it makes no sense because they get the power from same wire, I can't seem to find ground,I'm taking that negative wire in the socket is not grounded,and yet the left tailight works
69 Firebird
71 Cuda
Elite Custom Body
Stefan B.
02-21-2010 #5
