    Page 2 of 2 FirstFirst 1 2
    Results 21 to 34 of 34
      Dunwoody, GA
      Quote Originally Posted by David Pozzi View Post
      I just need to keep it out of Mary's evil grip! I have 2 cars it could go in, or a third I haven't even built yet.
      One problem is, I was fairly far along building a Brodix tall deck block 18 deg headed 427 for my 67 and I don't know if I should sell it or finish it and use it in the car.
      I like how smooth Steve's engine runs on the street, and the torque is great. It looks like working on the intake and Throttle Body would help. Cam change? Maybe.
      Two things about a supercharger, I think the compression is too high, and it would add some extra weight.
      David
      I wouldn't put an SC on the engine.
      Something to keep in mind if you aren't already aware. The FAST 102 has different runners available for it. You can test and tune the intake essentially. It's not a cheap setup but I think I would lean this direction so you can hopefully optimize the power with a day worth of dyno tunning. VMax Motorsports offers a cable operated 100 or 105mm billet throttle body that is gorgeous and will fit the front of that intake. I'm betting you'll want a 95 or 100 and not the 105 for great throttle response. Check with Pete at VMax or Mike Norris as he carriers VMax parts as well.
      Going with a carb style intake may be possible also. I can't remember but I believe they are all single plane only which could hurt bottom end if the runners are too large. It will definitely help top end though. I think the FAST 102 would be better simply because you can change runners.
      Then again, loose just a tad on the bottom but gain a bunch up top may work better on the courses you'll run. See how this could get out of hand quickly, lol.
      Trey
      ~ Jon Hammond
      SoCal
      Perhaps old fashioned cylinder head shaving is an option? Maybe a comparable but thinner head gasket is now available? Or are the valve clearances already too tight for that?
      You could get really fancy and start looking into variable cam timing. Cam phasers are becoming more common on the new GM engines. Sadly, I have no idea if it is remotely practicaly to retrofit such a setup onto an LS2.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      Central CA USA
      On the One Lap Camaro I have to watch out to not open the throttle too wide or the engine lays down a little at low speeds. Penny didn't do that at all but perhaps throttle by wire has something to do with it.
      The FAST 102 might be a good way to go. Does it fit the AFR ports? It's $400+ to port my current manifold, so maybe I could put that money towards a new intake. and a 95mm TB. Does the FAST 102 benefit from any porting work?
      Jul 2003
      Anaheim Hills, CA
      Yea, the now 102mm will work fine.. I can get you a discount on the intake and the rest is just plug and play.
      You can port your own intake.. especially with your skills. Not "hard" just time consuming.
      All intakes benefit.. but my guess is that the 102 will be good out of the box considering the heads on the engine.
      Mike Norris is the guy to talk to about massaging your TB.
      1968 Track Rat Camaro:
      Oct 2006
      Carlsbad, CA
      Call Charlie at RPM Motors. He's a well respected LSx engine builder and tuner, esp in the Corvette community.
      G.
      Apr 2002
      I can't see any potential work being worth the time or $$.
      That's a 8K motor to recreate and you're practically at 500 RWHP. I've studied the dyno section of ls1tech for years and it takes a lot of money to get 500 RWHP on gen III technology. The new LS3s are cheaper to get there.
      Cam swap $500 in parts.
      Head milling + $75 gaskets and new head bolts
      Intake - $500+
      TB Port - $125 for 10HP?
      Read any of Tony Mamo's posts...these are the details that get you the magic number but the investment is too much in my opinion. A new tune would probably move the power around for effectively than new parts.
      --JMarsa
      Central CA USA
      JMarsa,
      New tune?
      Are you saying I can have the ECM tuned and get more power? It's already been dyno tuned.
      A new cam costs $500? Why?
      I won't mill the heads, not worth it.
      TBI port, that's a lot for 10hp, but it looks cheaper than the other choices.
      The intake and TB has the most potential for the money. I'd have the old one to sell to offset buying a new one. I can port match or smooth up a new intake myself, just haven't done an LS intake before.
      If the TB got me 10hp and intake got me 20, that's 30 hp, that would put me right at 600hp. If that could be done with next to no loss of low end it is sounding good. A little more cam and who knows?
      I may not decide to do it, but I need to hear my options now, while the engine is still out of the car. I have more reading up to do on these engines.
      I didn't want to confuse things by bringing this up, but I also have another engine that could use the old FAST 90 intake and AFR heads, and I could buy new parts for the 402, like new intake and ported LS3 type heads.
      Apr 2002
      Usually a dyno tune will get you top numbers. But you can have a tuner spend a day with the can on the street (forgot you don't have the engine installed yet) and he can tweak the timing and fuel to slide around the power curve a bit.
      Selling parts like an intake to offset the cost of new ones will bring you about .75 on the dollar. It's not like they wear out and there's strong demand.
      Usually a cam kit is purchased, cam, lifters and pushrods (maybe you won't need new ones) here's some examples:
      http://www.thunderracing.com/catalog...&vid=7&pcid=51
      Instead of an intake I would go with a UD pulley and possibly a EWP. As said earlier, it doesn't look like your air limited. Good headers can made a difference, but it depends on the car, on a 'vette you can see a 10-15HP variance between the vendors.
      On ls1tech this guy is local to me: 'allngn_c5' he's spent a ton of dough going from 490 RWHP to:
      LS2 402 - 541 rwhp 505 rwtq Tuned by Vengeance Racing
      TFS 215's (59cc) Custom Cam, 1 7/8 ARH, Ported FAST 92, UD Pully, EWP
      --JMarsa
      Dunwoody, GA
      If your current FAST 90 isn't ported, get that done. I missed that and thought you had the LS2 intake on the engine. The differences between your engine and the vengeance 402 aren't worth the efforts. They got nice peak numbers out of the car but the torque isn't much broader than your curve. It's moved up in the RPM band a tad but holds on longer. Better intake will be the cheapest way to extend your torque band into the upper RPMs which is the biggest advantage that engine has over your current setup.
      Trey
      ~ Jon Hammond
      Central CA USA
      Sorry I don't fully speak LS yet. What is "possibly a EWP" ?
      Thanks for the info guys!
      David
      Apr 2002
      :-) electric water pump, Under drive pulley = UD
      --JMarsa
      Central CA USA
      Thanks Max. I'm lurking a lot too!
      Tallahassee + Seminole, Florida
      http://www.ls1tech.com/forums/12670469-post20.html
      There are a couple LSXR numbers. Looks like it is good for about 12-15hp over a stock LS3, with no portwork possible (hardly impressive)
      Dyno:
      http://www.ls1tech.com/forums/12356431-post22.html
      So... you can make those kinds of gains by porting a stock intake, and even more with ported FAST 92 (again, I don't have any info regarding the 90).
      Here is a link to the Formato specials: looks like a FAST + TB is $375. I was wrong about the numbers; he is getting 15-17/18-21 on a stock LS2 manifold. Not bad.
      http://forums.corvetteforum.com/c6-z...g-special.html
      David -
      Been reading a lot of good things about the 102, especially on LS2s. I'll try and dig up some links, but the general consensus seems to be that it flows like a champ and would be great for your application. I know this is contrary to some of the early reports I posted... just trying to get you some good info.
      Max
