    Results 1 to 18 of 18
      Oct 2009
      Bentonville AR
      69 Camaro Project Vert
      My project begins
      Tony at Muscle Car Metal did an excellent job restoring the shell.
      He also installed the Art Morrison rear subframe during the build that Frank at Prodigy Customs ordered for me. I have a feeling Frank will be getting a lot of my money during this build.
      DSE mini tubs installed
      Got it on the rotisserie
      Lawrenceburg, TN
      looks good!!
      Oct 2009
      Bentonville AR
      Plans
      Plans for the project:
      - 6.2 liter All Aluminum L92 with LS3 intake
      - Considering the TCI 6x automatic six speed transmission
      - Ricks stainless EFI tank
      - Art Morrison front subframe and subframe connectors
      - Willwood Brake Package
      - Forgeline Wheels
      - Smooth firewall and relocated wiper motor
      - Custom black interior
      - Have not decided on exterior color yet
      Nice project keep us updated. Tony does some nice work.
      Awesome, nice to see a convertible for a change.
      Laine O
      LIVE LOVE DRIVE!
      Oct 2009
      Bentonville AR
      Next step in the project
      Need some help from the experts. I am going to prep and coat the underside with a bed liner and need to make sure I have the steps correct so it turns out good.
      1. Sand any surface rust that may be present on the non edp coated pieces such as the subframe and mini tubs (will 180 grit work?)
      2. Red Scotch bright the areas to spray that have the edp coating or should I just use 180 grit?
      3. Clean with waterborne wax and grease remover
      4. Dry the panels and then wipe down with tack cloth
      5. Spray SPI epoxy primer (How many coats?)
      6. Seam seal all the panels (any recommendations or favorites for sealer?)
      7. Should I put another coat of epoxy primer on and what is my time window from first coat of epoxy primer?
      8. Apply bedliner coating (What is my window to put over the epoxy primer without having to scuff with red scotch bright?)
      9. What are your recommendations for undercoating? I was looking at Raptor or SPI.
      Please give me your input to the above info on what I am using and if I have the steps in the right order.
      Colin
      Oct 2009
      Bentonville AR
      During the build
      Here are some pictures during the build process:
      St.Anne Il
      great project i have a dynacorn convert i picked up last year that has 4 link and c4 front clip ill be starting on soon ..i love converts..i will be following your for sure..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Mountain Springs, Texas
      I'm not so sure that I would put bedliner on all that new metal. I would just epoxy prime it and apply chassis black. I think buyers wonder what is under bedliner when they see it on a car.
      I like to use the two part 3M seam sealers.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2011
      dallas, tx
      when are you going to start the progress pic?
      Oct 2009
      Bentonville AR
      Starting to make some progress. The car is now at Rod's Car Craft.
      Art Morrison front subframe delivered
      Oct 2009
      Bentonville AR
      Smoothing out the firewall
      Car on wheels
      Oct 2009
      Bentonville AR
      Subframe connectors being installed
      Oct 2009
      Bentonville AR
      It is now sitting on the ground
      The Piedmont Triad, NC
      Great looking build, figured out a color yet?
      67 LeMans Convertible
      67 GTO
      69 Camaro Build Thread https://www.pro-touring.com/showthre...ost-Money-quot
      70 Chevelle 400 4spd
      70 Chevelle
      Oct 2009
      Bentonville AR
      Color
      I am thinking about Cyber Gray
      I was looking at that paint chip the other day for one of my Chevelle's haha
      67 GTO
      70 Chevelle
