Thread: LS-3 Valve Springs
02-12-2010 #1
- Feb 2007
- USA, TN
- 850
LS-3 Valve Springs
I purchased a set of LS-3 valve springs that I'm installing in my ZZ-4 so I can run 1.6 rockers. The question is, what should I set the install height to?
My confussion is the LS-3 springs allow the bigger valves in the LS motor spin to 6600 RPM with the lighter beehive springs. Should I set them at 93 lbs at the seat or 105 lbs at the seat? I want the engine to spin past 6000 RPM.
The specs are 86 Lbs at 1.8 inch and 105 Lbs at 1.75 inch. The rate is 387 lbs and coil bind is 1.1 inch
The ZZ4 uses a spring with 100 lbs at the seat. The LS-3 uses 90 lbs at the seat
