- Dec 2004
- 203
EFI wanted-convert SBC, LS1 or 502BB?
I am working on my first project, a 1968 camaro and am finishing up the chassis/suspension/braking/steering work and want to drive it for a little while with the current motor and tranny, a sbc 350, with ported 1969 camel hump heads and a comp cam, roller rockers, edelbrock carb, aluminum flywheel, milodon high volume oil pump, lakewood bellhousing, and a rebuilt Muncie M21. It makes good torque and i currently have a 3.77:1 rear with Posi. Incidently, i have cast iron intake 14057055 with date code K82--anyone know what this is from and if it is desirable?
I would like to make the switch to EFI, for driveability and economy and hopefully a little more power. I would say my budget is mid-range. I have been looking at the LS1 crate motors, and it looks like ready to go packages are around $7500. Of course i could also conver the current block to EFI but i think if i did to make the torque i'd like to make (400-450 ft/lb) i may have to stroke it to 383? Then i see the GM 502 fuel injected crate motor for $6,999 from Jeg's with "some assembly required". This makes 565 lb/ft! The fuel injected 350 crate won't get me to the numbers i want. Are there comparably priced fuel injected 383 crate motors out there that people can recommend?
My biggest questions are what are the hidden costs and what are the differences in weight between these options? I haven't been able to find published weight for the 502. I'm putting the camaro together for driving, and have added DSE power steering, front coilover conversion, Baer 13s in front and 12s in the rear with the lowered leaf springs from DSE out back. Will the extra weight of the bb (anyone know exactly what it is? it does have al intake and heads) neccessatate changes in suspension or ruin handling? Are there other costs associated with it that i'm not aware of? I plan to change to a manual overdrive tranny as well but would like to do one at a time to spread the financial burden out a little.
I'd appreciate anyone's input as to pros/cons.
Thanks!
