Results 41 to 57 of 57
Thread: Chevelle EFI install...
09-11-2010 #41
- Oct 2004
- Papillion, NE
- 203
The TFI module part number is F121 from Autozone, $38.99, and can be changed externally
The Hall effect switch, also called the pickup, is an F122 for $17.99 from Autozone. It cannot be changed from the outside, you have to drive the distributor gear off then pull the shaft upwards and it unbolts easily.
It looks like you can get at the Hall Effect switch from the top, and you can, but you risk losing the shutter wheel timing for the fuel injection. Its a splined shaft and if you don't put it back in the right place, the injector timing will be off. It's FAR easier to pull the distributor and gear.
If it is just the F121 TFI module, and you burn a second one, there is a company that makes an adapter for a remote one, and the price is reasonable. They really don't like heat.
http://www.mccullyracingmotors.com/i...es/tfikits.htm
If mine fails, I'll go with this kit.70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
