    Results 1 to 9 of 9
      Jun 2009
      Cape Coral, FL
      need a master cylinder!
      So I ordered a modified clutch mastercylinder for my t-56 from ats in NOVEMBER and it still hasnt been processed. I sent an email back in december and I was notified that they were bought but the new guys would be shipping stuff out in JANUARY. Well after 3 months I've given up so where can I get a modifed clutch master? I tried to modify my push rod by cutting then threading it, but there just wasnt enough meat on there to work.
      I have a t-56 out of an 06 GTO, I replaced the slave with one from an 02 camaro. Is there anyway to replace the push rod with something else?
      Also I already have a mount from S&P for the firewall.
      Rockford Illinois
      I don't know how much length you have to work with but I have used a piece of round stock and drilled one hole to the size of the rod that you are trying to thread and drill and tap the other side to the size you need and then press the stock on the rod and weld the end of it.
      Jun 2009
      Cape Coral, FL
      Quote Originally Posted by Jim Nilsen View Post
      That is a good idea, but my mastercylinder is done lol and I don't wan't to buy a new one just to mess it up (can't weld for the life of me)
      But thanks for the input man! Anyone else know where I can get my hand on one of these? Help a brotha out!
      Boonville, Missouri
      What exactly are you looking for - a turnbuckle? They are threaded right and left hand thread and your mount your end to it and adjust away and use a jam nut to lock it into place.
      You can find these at midwest control products or McMaster Carr.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Rustburg, Virginia
      How about this?
      Jun 2009
      Cape Coral, FL
      Quote Originally Posted by Bigblue73 View Post
      I'm looking for the whole master cylinder unit. I already tried that method, the only problem i have to go so low on that push rod I have to remove the top half of it, leaving a small diameter push rod that will most deff break. I'll try to post pictures to illustrate.
      Jun 2009
      Cape Coral, FL
      anybody have any ideas? or know where to get one?
      Rustburg, Virginia
      Will the Wilwood unit work for you?
      http://www.speedwaymotors.com/Wilwoo...isplayId=31419
      Jun 2009
      Cape Coral, FL
      i looked up the wilwood kit and came accross a mcleod master http://dagostinoracing.com/index.php...4&currency=USD
      i think i can thread the push rod alot better on this master compared to the 02 camaro's, it'll looks to have a larger diameter the entire way. but before i drop 350 to destroy something, what do you guys think?
      thanks alot for advice!
