    Results 1 to 13 of 13
      SoCal
      shaving door handles
      I'm patching up the door handle holes, and want to make sure I'm not doing something wrong. I'm tacking a patch piece all the way around the edge until it's fully tacked, then grinding, then adding more metal as needed, then grinding. I'm being careful not to heat up the sheetmetal too much via welding or grinding. I can still barely see a crack around the edge of the repair after grinding - is this normal? It's not going to fall out after a while is it?
      Feb 2003
      St. Louis, Missouri
      Sounds like you may be grinding it down too far. The other thing that I see is that those welds should touch, in other words, there needs to be a continuous weld all the way around your repair, every gap should be tacked.
      SoCal
      Yeah, that first picture wasn't just before I started grinding - it was about halfway. I had tacked all the way around before I started grinding.
      Aug 2003
      I do not see any penetration in those welds. The cracking is what is called undercut which means it is not bound well. You would be better off to have a bit of warping and use a little bondo, then to not have penetration.
      It will suck big time when you perfectly straihgt, not warped sheetmetal work falls out of your killer paint job one day when you close the door.
      SoCal
      Thanks Frank, that's the kind of feedback I'm looking for.... So do I increase the heat on the gun, or just keep it on longer and start to make a longer bead?
      Nov 2003
      Maine
      tom
      sorry for butting in, but ou want to give it some more heat, but do not make longer welds, do 2-3 around patch then let sit for awhile, then go back, you should not have a big puddle build up, it should almost melt in, without burning thru
      goodluck
      jake
      Aug 2003
      Yeah, what he said!
      Shenzhen, China
      Looking good there man.
      Every time I shave my door handles they just grow back. ;)
      PhaseShift
      www.rscamaro.com
      ShenZhen China- 6.8 Million people and only 40 or 50 good drivers. All I can do is envy them as I ride trapped in a Korean made mini-van.
      NY
      The crack you're seeing, is probably the seam of your repair. Your welds look like you're getting SOME penetration, on the two pieces, but if you're grinding an seeing the seam you're NOT getting full penetration. Heat is definitely and issue. (machine set too cold, or not building the puddle enough so the heat from it causes the puddle to "flow" out) Try backing it up with copper Eastwood has 2 items that would be of help to you. 19108A Soft Copper Triangle $12.99 and 19038 Welders Helper $19.99
      The welder's helper is slightly curved, but does not bend. Where the soft copper triangle is flexible. I also agree with 68protouring454. Do a few spots on opposite sides of the patch and let cool to the point of being touchable. Then follow it up with a few more spots right next to those, etc., etc., etc. It takes allot of time, and that sucks but you want to do a quality job. Especially on something you are going to see every time you go to get in the car. Patience is the key.
      Good Luck!
      SoCal
      Ok, trying again now... thanks guys!
      SoCal
      2nd try...
      Ok, started to shave the handles of the new door skin. I think it's turning out much better this time...
      Aug 2003
      You want a job? looks good man.
      Nov 2003
      Maine
      nice work
      looks great, good work
      jake
