      Orlando, Fl
      Coilover question
      I am in the process of installing coilovers on my 73 Z/28. I am modding my frame and my newly purchased Hotchkis lower control arms.
      I am trying to decide... Do I use bearings or bushings in the coil overs?
      Pics for clicks!
      Nick DiPrenda
      Orlando, Fl
      I will add a little more info. The car will see mostly spirited driving on the street. Definitely some autocross and open track days as well.
      I am leaning towards a bushing control arm side and a COM8 bearing frame side. Any reason to do otherwise??
      Nick DiPrenda
      Loganville, GA
      I would lean toward the bearings, a bit more precise response, i.e. no bushing give/deflection.
      While you're at it, you could do the 2nd gen mod (similar to 1st gen Guldstrand mod) that the Trans-Am racers did. I believe they lowered the control arm mount down 3/4" which brought the roll center up some and lowered the rear bolt hole 3/8" for some more anti-dive. The info is out there, but I can't locate it right now. I may have it at home. If so I will get it to you.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Orlando, Fl
      Quote Originally Posted by Randy67 View Post
      I actually have the Herb Adams (I think) booklet outlining all of those mods. I was debating those mods, though I am also using Hotchkis control arms, so not sure if they are necessary.
      Nick DiPrenda
      Loganville, GA
      Unless the Hotchkis arms have taller upper ball joints, they won't change the roll center, but they should add needed caster though. Won't hurt to do the mod with those arms, every bit helps they say. SC&C uses a taller upper ball joint to get the same effect (except for the anti-dive part).
      1975 MGB Roadster
      2003 GSX750F Katana
