Results 1 to 10 of 10
Thread: Another spring and spring rate Q
02-03-2010 #1
After selling my front 2"drop hotchkis springs off the front of my nova because i wanted to go coilover and lower the car more by raising the upper mount for the coilover i've come to a very bad realization, i can't go any lower than i was or i will be riding on the bumpstops. The only way around that would be drop spindles which i refuse to use or the ats spindles which i can't afford.
So the question comes now, should i just go back to a spring and shock combo? I did like the hotchkis springs but i never got a good set of shocks and i guess could never truely got to see them for what they could be.
I do plan on autocrossing the car frequently and i will be driving it on the street, however i am more performance oriented than comfort oriented which leads me toward something like a 650lb spring. I hear that bilstein makes a good shock but i don't know what would work well in my situation. Would an adjustable shock work out better and what spring/shock combo would you recommend? Keep in mind i am on a very strict budget.
Car Info.
1972 Nova, sbc still iron heads but hopefully going aluminum at some point, stock uca's and lca's but will hopefully be getting SCC adjustable uca's, i want to switch my poly lca bushings to solid or delrin, solid body mount bushings, subframe connectors, Hellwig 1 1/4" fsb, stock subframe, rear will be getting a custom triangulated 4-link and most likely 250lb coilovers, i was looking at the competition engineering 3 way adjustable coilovers. I know the front bar is probably too big but i was going to look into an adjustable rear bar to help tune it.
I feel like I screwed up royally by getting rid of my old front springs but maybe i can go a different route and get the same ride height and maybe have better performance?Jason Nichols
'72 Chevy Nova-The Blue Bomb https://www.pro-touring.com/showthre...972-Chevy-Nova
02-04-2010 #2
The car in question.Jason Nichols
02-04-2010 #3
