    Results 1 to 9 of 9
      Nov 2001
      Sacramento Ca
      FAST EZefi question
      I want to run this system on my Corvair.
      They make a nifty 4150 ready manifold for my type engine, and this EFI setup is a dream come true for litterally hundreds of us Corvair enthusiasts.
      But there is an issue. It says in the literature, that it uses a "coolant temperature sensor"
      Corvairs dont *have* coolant. And our head temps get up to around 400 to 500 degrees on some runs. That's where the boss is for the temperature sending units we use.
      I remember hearing this could be worked around. But i dont remember where, or how.
      Tony Langlois
      1966 Corvair Monza
      Miami, FL
      Run the CTS in the oil pan or at least touch it to it with a bracket.
      The coolant temp sensor is the input for the "choke " function of EFI. Without it, cold start is tough. We have done this in aircooled Porsches without a problem.
      Oct 2009
      Toronto, Ontario
      You can ask the engineers that designed it here:
      http://www.cpgnation.com/forum/fast-...t-support.html
      Lawrenceburg, TN
      that's a great link 7t2vette!! spent some time in there good pull thanks
      Aug 2003
      I was thinking oil temp would work to.
      Oct 2009
      Toronto, Ontario
      Quote Originally Posted by rusty68 View Post
      No problem!
      I am currently installing the EZ-EFI on the sbc 406 in my '72 vette, and one of the moderators (bluzman2004) at the forum I posted the link to is also a member at Corvetteforum.com, which is where I met him. He is one of the engineers that developed the EZ-EFI system.
      Feb 2007
      USA, TN
      I don't mean to hi-jack the thread, but do the injectors spray above or below the throttle blades on the Ez-EFI?
      Indianapolis, IN
      The oil temp trick is a good alternative for sure.
      The injectors spray just below the throttle blades.
      Mike Norris
      Mike Norris
      Oct 2009
      Toronto, Ontario
      Quote Originally Posted by TnBlkC230WZ View Post
      The injectors spray below the throttle blades.
