    Results 1 to 11 of 11
      FL and Calif.
      I have fuel line build going on too. And as well have ricks tank with 225 pump. I did email to aeromotive ( since i have their regulator and filter) about placing the regulator near tank to with single line up front . They did recomend to use return line and mount regulator close to engine.
      Feb 2007
      USA, TN
      I'm not an expert, but this is my underdstanding of the topic.
      With a single line going to the fuel rail and the rail is dead headed:
      When engine fuel demand suddenly and dramatically increases, pressure on the line will momentarily drop slightly. This is a 1/4 - 1/2 second event and maybe an average of a 5 a psi drop until the pump brings the line pressure back up.
      GM has figured out how to size everything to minimize this event. If I were building a system like this, I would want the regulator or return style fuel filter as far away from the engine as possible. The longer fuel line with more pressurized fuel available will minimize the pressure drop and monentary lean condition.
      Properly done, the slight lean condition will not be noticable. I wouldn't do it on a turbo or supercharged applicaiton.
      Fuel system with the regulator on the return side of the fuel rail:
      The fuel pressure will remain constant on the fuel injector side of the fuel system.
      Henderson,NV
      Everytime I see this topic, I always say it's not a returnless system. It's a very short return. GM has it figured out.
      Todd
      Rockford Illinois
      According to the accel DFI a dead headed fuel rail is returnless even though some would misconstrue the parts involved but if you read the instructions fully it really comes down to dead head or flow thru.
      Henderson,NV
      I can see how they could argue it's a dead headed system. The fact of the matter is, the pump can run at full sail and be ready for that wide open throttle blast. In a true dead head system, the pump is bleeding off the pressure similar to an oil pump.
      Todd
