    Results 1 to 14 of 14
      Oct 2005
      New Washington, IN
      low budget ls carbed combo?
      Here is what I want to do. Buy an lsx from salvage yard, swap cam, heads?, and intake. Going with carb set up.
      Not looking for most power, but best 'bang for buck'
      Car to be installed in is typical budget prop touring car. Use of car is close to daily driven. Road trips, cruizing, 'spirited driving'.
      Car is 3200lbs, has ls series 6 speed, 3.23 rear gears, 27" tall tire. swap headers,No ac.
      So, what would be the best long block for the least cost? Would rather not swap haeds if not a must, and cam idea? I know when time comes I will also look into cam companies recommendation as well.
      Thanks in advance
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Petersham ,ma
      i vote this, 6.0 lq4,l92 heads,4v intake comp cam....can be done cheap
      http://www.carcraft.com/techarticles...ads/index.html
      thinking of this combo myself
      Oct 2005
      New Washington, IN
      Thanks, I remeber that article. Thats right along the lines of what I was thinking.
      North Carolina
      my vote for an lq4 also, thats what I'm running.
      1969 Chevy Camaro
      D&D T-56, 04 LQ4
      Feb 2007
      USA, TN
      I've seen LY6s on ebay for under 2K. It won't have the wiring or manifold, but you don't need it. They already have L92 heads, so you will only need to change the cam, Timing gears and valve springs.
      Oct 2005
      New Washington, IN
      I see the LY6 has variable valve timing. Will this affect my plan? Does it change any hard parts?
      The best bang for the buck is definitely the LY6. Its basically a GEN IV LQ9 with L92 heads. A cam a springs really wake it up.
      Oct 2005
      New Washington, IN
      Any tips on identifying an LY6 motor compared to the LQ9?
      It will say GEN IV 6.0, have a VVT front timing cover, and have L92 heads (Casting 823 or 5XXX).
      Oct 2005
      New Washington, IN
      Thanks for the info!
      Aug 2009
      Hey Johnny,
      You need to give this guy a call. He can really really help you. He's the one helping me with my LS build and swap.
      His name is Bart and his # 678 446 0653.
      Oct 2007
      Wa
      What is your idea of budget?
      Bob
      Oct 2005
      New Washington, IN
      $4000.
      Have a couple lines on LY6's for around $1000
      Feb 2007
      USA, TN
      Quote Originally Posted by Johnny Blaze View Post
      You will have to change the cam, gears and chain if you are not running the computer, but you mentioned you were changing those anyway.
