      Oct 2008
      400hp LS 6.2 valve problems?
      My sister has a 2007 Escalade Ext with the 400hp 6.2 LS motor. Last Friday the truck did a heavy shimmy shake and stopped dead on the hwy. Long story short, the dealer pulled the valve cover and discovered the engine had swallowed a valve into the motor. Dealer said this is a common problem with the 6.2 and that they will do a full longblock crate motor exchange. Apparently these motors have a "hardened" valve that has been breaking from being too hard to the point of being brittle. Truck has 53000 miles. Has anyone seen or heard of this problem? Dealer said it is a common and they don't even bother to repair the motors anymore, they just change them out.
      69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
      Walla Walla, WA
      I've heard of this. It's supposed to be an L92 problem, not an LS3 issue. The LS3 head uses different valves.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Miami
      Quote Originally Posted by Mkelcy View Post
      Can you tell me more about it since I have a L92 engine that I am using in my 55' chevy project?
      Walla Walla, WA
      Here's the only thing I could find on a quick Google search: http://forum.grrrr8.net/showthread.php?p=177239
      Note that Denali's came with L92 engines, not LS3s.
      Miami
      cool. I dropped it into my favorites folder so as I get further along I can discuss...
      Jan 2010
      I've had it happen on alot of LS7's.
