      florida
      rear caliper hanging up
      I have power disc, disc with a 1 inch bore m/c and a 8 inch booster. the lines are all 3/16". front calipers are c4 grand sport rears are willwood 4 piston. bled system many times.shimmed willwood calipers to center? still hanging up. any suggestions?
      Oregon
      What do you mean by "hanging up"? Is one or both rear calipers having the issue? If it's only one, that would rule out the MC/booster since they're both on the same hydraulic circuit. That would most likely make it either a caliper hose or caliper issue.
      Tobin
      KORE3
      It's what I does.
      bowling green,ky
      your pushrod in your mc may be too long? i had that problem w/my setup when i went to 4whl disc
      florida
      ill have to see if my push rod is adjustable thanks.both calipers in rear seem to hang up.
