    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    Thread: big red aero?
      Mar 2003
      Kirkland, WA
      Bobby Isaac- Feb.21,1964 at Daytona Int'l Speedway, Florida Average speed-169.811MPH......Won $1100.
      Wouldn't this be around 300 rwhp or so? Seems pretty reasonable for a full tilt race engine 40 years ago. Just because modern cars can do this kind of MPH pretty easily doesn't mean that older cars can.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Central CA USA
      Here is an online aero drag calculator: http://www.gtechprosupport.com/support/AeroDragCalc.htm
      I assume the HP required would be rear wheel HP.
      if you look at it, it's basically the same equation, not sure why they have 150,000 when I came up with 140,000 as the unit conversion, maybe a slightly different air density value? Anyways, it's the same. The speed posted by James would be more like 400 rwhp using chevelle drag and area values. Still doable I think even back then. Remember, around that period was when 426 hemis were making their way into racing, so that probably helped!
      Mar 2003
      Kirkland, WA
      I was gonna say, didn't Nascar allow big blocks at one time? I don't think that Nascar had the same limitations on engine development then as they do today, the technology was still pretty new at that point, and the potential for development kept everyone relatively equal. Still 400 rwhp would sure be interesting to drive in a "stock car" that was still pretty much stock.
      James
      -1996 Z28
      -2005 Silverado
      Webpage
      Central CA USA
      Here is one that does rolling and aero drag: http://www.bgsoflex.com/aero.html
      westchester county new york
      my understanding is that the old nascar boats made a ton more power than todays cars.
      also I know that the tiniest adjustment in a car (ride height, duct tape over openings, mirrors on or off) makes a huge difference so there has got to be some range in those formulas.
      I stink at math but am I right about this ? you only know the exact drag coefficient if you test the car in wind tunnel set up the way it will run...???
      all those tiny adjustments are changing your Cd, which yes you don't know exactly until you test it in a tunnel. It's an important distinction that the innacuracy is not in the equation, it's in the supplied data.
      thanks.
