    Page 2 of 2 FirstFirst 1 2
    Results 21 to 25 of 25
    1. #21
      Jul 2001
      Detroit, Michigan
      Do you have any pictures of Aperture being used to tape jambs? I'm having trouble picturing how it would go on and how it would work.
      *edit* Nevermind....I found some illustrations of the process elsewhere on the internet. I'm guessing I can buy it at my local paint store.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
    2. #22
      Toronto, Canada
      I have never done this its all in therory but what about painting the jambs after the body is painted?? I think this would work well and I am planning on trying it in the near future, if the entire car is going to be cut and polished than any over spray that gets on the body will be sanded out in the process, and even if you did tape off the body near the jambs you could sand out the tape line right to the door jab edge and polish it. what do you guys think?
    3. #23
      Nov 2003
      NE Ohio
      Tony,
      Here is a great alternative to using a garage compressor, lines, filters, seperators, etc.
      Plug turbine unit into 115 volt outlet, hook up hose to HVLP spray gun, turn on power and spray. The system actually warms the air, so moisture is eliminated, supplying dry, oil-free air to the paint gun. Warm air helps paint dry faster, so runs and sags are eliminated.
      Turbines systems deliver a high CFM of air (60-80 cfm) but at low pressure (4-5 psi). The low pressure reduces overspray while the high volume of air moves the material. Paint goes on smooth with less mist, resulting in a 30%-50% paint material savings.
      There is even a 2 Year Warranty, and a 30 DAY FREE TRIAL! TP Tools will actually let you try the turbine system in your shop for 30 days and if you are not 100% satisfied, return the unit in its original carton for a full refund or credit, less freight. (Subject to a cleanup charge if not returned in like-new condition.) They claim to have sold thousands of units on this basis over the years and find that those who use our the HVLP Turbine LOVE IT!
      -- HVLP Turbine Paint Systems --
    4. #24
      Jul 2001
      Detroit, Michigan
      Thanks for the info, Rich. I have decided to rent a paint booth near my house instead. It's affordable and will make the job a lot easier.
      Project: Next Year
    5. #25
      Feb 2003
      St. Louis, Missouri
      Quick GN, it's possible to do after the outside is painted, but again, you'll get tape lines. I've done it every way possible, and painting the jambs at the same time as the car, for me, yields the best results.
